Solving Riddle: Find Closest 2 Points on a Plane in O(N)
  • Thread starter Thread starter Atlas
    Plane Points
Atlas
Here's a riddle I'm having trouble solving:
There are N points on a plane. Find the two points that are closest, in time better than O(N^2).
Any idea?
Mathematics news on Phys.org
randomly pick point p. then choose point P+1... :-P
Nice problem. Are you sure there is a solution? I'll think on it some more if you know that it can be solved (well, I'll think on it anyways).
I know there's a so-called "simple" solution that requires O(N * log^2(N)), and a more complex one that requires O(N * log(N)).
Here's a hint:
If the problem was "Given an arbitrary function f(P, Q) of two points, find the pair of points that minimizes f(P, Q)", can you prove that the best algorithm is Θ(n²)?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
