Solving series with complex exponentials.
  • Thread starter Thread starter yungman
    Complex Series
34 replies · 5K views
yungman
I don't know how to come up with this final solution:
[tex]1+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}=1+\frac{re^{j(\theta-\phi)}}{a-re^{j(\theta-\phi)}}+\frac{re^{-j(\theta-\phi)}}{a-re^{-j(\theta-\phi)}}=\frac{a^2-r^2}{a^2-2at\cos(\theta-\phi)+r^2}[/tex]
For [itex]\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}[/itex], multiply by [itex]\frac{a-re^{j(\theta-\phi)}}{a-re^{j(\theta-\phi)}}[/itex]
[tex]\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}(a-re^{j(\theta-\phi)})[/tex]
[tex]=\frac{ar^n e^{jn(\theta-\phi)}}{a^n}-\frac{r^{n+1}e^{j(n+1)(\theta-\phi)}}{a^n}+\frac{ar^{n-1} e^{j(n-1)(\theta-\phi)}}{a^{n-1}}-\frac{r^{n}e^{j(n(\theta-\phi)}}{a^{n-1}}\cdot \cdot \cdot \cdot\cdot \cdot+\frac{are^{j(\theta-\phi)}}{a}-\frac{r^2e^{j2(\theta-\phi)}}{a}[/tex]
[tex]=re^{j(\theta-\phi)}-\frac{r^{n+1}e^{j(n+1)(\theta-\phi)}}{a^n}[/tex]
[tex]\Rightarrow\;\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}=\frac{re^{j(\theta-\phi)}-\frac{r^{n+1}e^{j(n+1)(\theta-\phi)}}{a^n}}{a-re^{j(\theta-\phi)}}[/tex]
The same steps are use:
[tex]\Rightarrow\;\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}=\frac{re^{-j(\theta-\phi)}-\frac{r^{n+1}e^{-j(n+1)(\theta-\phi)}}{a^n}}{a-re^{-j(\theta-\phi)}}[/tex]I expand the series out. You can see most cancel each other and leaving only two terms which factored out into 4 simpler terms. You can see two of the terms match the answer:
[tex]1+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}=1+\frac{re^{j(\theta-\phi)}}{a-re^{j(\theta-\phi)}}-\frac{\frac{r^{n+1}e^{j(n+1)(\theta-\phi)}}{a^n}} {a-re^{j(\theta-\phi)}} +\frac{re^{-j(\theta-\phi)}}{a-re^{-j(\theta-\phi)}}-\frac{\frac{r^{n+1}e^{-j(n+1)(\theta-\phi)}}{a^n}} {a-re^{-j(\theta-\phi)}}[/tex]
Compare with [itex]1+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}=1+\frac{re^{j(\theta-\phi)}}{a-re^{j(\theta-\phi)}}+\frac{re^{-j(\theta-\phi)}}{a-re^{-j(\theta-\phi)}}[/itex]
[tex]\Rightarrow\;\frac{\frac{r^{n+1}e^{j(n+1)(\theta-\phi)}}{a^n}} {a-re^{j(\theta-\phi)}}+\frac{\frac{r^{n+1}e^{-j(n+1)(\theta-\phi)}}{a^n}} {a-re^{-j(\theta-\phi)}}=0[/tex]
I have no idea how to make this zero, please help.
Thanks
I can't follow at all what you have done, so I can't comment on it.
Perhaps the best approach would be to use the commonly known result for geometric series: [tex]\sum_{n=0}^\infty x^n = \frac{1}{1-x}[/tex] for [itex]|x| < 1[/itex]
Thanks for the reply.
It is given [itex]r\leq a[/itex] and also [itex]|e^{j(\theta-\phi)}|\leq 1[/itex]. So that fits [itex]|x|\leq 1[/itex]
[tex]\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}\;\Rightarrow\;x=\left(\frac{r}{a}\right) e^{j(\theta-\phi)}\;\Rightarrow\;\frac{1}{1-x}=\frac{a}{a-re^{j(\theta-\phi)}}[/tex]
[tex]\Rightarrow\;\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}\;\Rightarrow\;x=\left(\frac{r}{a}\right) e^{-j(\theta-\phi)} \;\Rightarrow\;\frac{1}{1-x}=\frac{a}{a-re^{-j(\theta-\phi)}}[/tex]
But that will give:
[tex]1+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}=1+\frac{a}{a-re^{j(\theta-\phi)}}+\frac{a}{a-re^{-j(\theta-\phi)}}[/tex]
That's does not give the right answer. Please help.
Notice that the summation in clamtrox' post starts at ##0## and yours starts at ##1##.
Thanks, I missed that. I have to see whether it's making any difference.
So with the extra term of [itex]n=0[/itex], both will give a 1 for [itex]n=0[/itex].
[tex]1+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}=1+\frac{a}{a-re^{j(\theta-\phi)}}+\frac{a}{a-re^{-j(\theta-\phi)}}+2[/tex]
I then factor 1 into one of the fraction:
[tex]1+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}=1+\frac{a}{a-re^{j(\theta-\phi)}}+\frac{a}{a-re^{-j(\theta-\phi)}}+2=1+\frac{2a-re^{j(\theta-\phi)}}{a-re^{j(\theta-\phi)}}+\frac{2a-re^{-j(\theta-\phi)}}{a-re^{-j(\theta-\phi)}}[/tex]
I still cannot get the right answer.
Don't you think that should be -2 instead of +2?
You can then give -1 to each of the fraction to get the right answer.
Can you explain how you can make it to -1. If you look at post #3, it's all positive result. n=0 then the result is +1. I don't understand why you can assign -1 to it. Please help.
Thanks
Thanks
You agree that
$$\sum_{i=0}^{\infty} x^i=\frac{1}{1-x}$$
for ##|x| < 1##.
The above series is:
$$1+x+x^2+x^3+...=\frac{1}{1-x}$$
Subtract 1 from both the sides to get
$$\sum_{i=1}^{\infty} x^i =\frac{1}{1-x}-1$$
Do you agree and does this clear your doubt?
[tex]\sum_{n=1}^\infty x^n = x \sum_{n=0}^\infty x^n[/tex]
[tex]\sum_{k=m}^\infty ar^k=\frac{ar^m}{1-r}[/tex]
Here is the more general formula, it should be easier to go from here.
Pranav-Arora said:
You agree that
for ##|x| \leqslant 1##.
Yes, I made a mistake, it's -1 instead.
The book suggested the method in my original post and I just don't see how that work!
Do you have a link that explain a little more on this? What is the limit of [itex]r[/itex] in this?
Pranav-Arora said:
Thanks for your help. Lastly I just want to verify this:
[tex]\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}\;\Rightarrow\;x=\left(\frac{r}{a}\right) e^{j(\theta-\phi)}[/tex]
It is given ##r\leq a## so ##\left(\frac{r}{a}\right)^n\leq 1##
[tex]|e^{jn(\theta-\phi)}|=e^{jn(\theta-\phi)}e^{-jn(\theta-\phi)}=1[/tex]
[tex]\Rightarrow\;|x|=\left|\left(\frac{r}{a}\right) e^{j(\theta-\phi)}\right|\leq 1[/tex]
Thanks
Pranav-Arora said:
I just read through the article. I don't think this can work for my problem. As posted, the ##r\leq 1## in my case. This does not work for ##r=1## as the denominator become zero and the solution is unbounded.
So I have to go back to my original post #1. Maybe that's the reason the book used a complicated formula.
Please help.
Thanks
Please help.
Thanks
You are right, and that is also the reason I edited my previous post.
Can you perhaps post the complete problem statement? I don't see the bounds stated anywhere in the OP.
This is part of the derivation of Laplace equation on a disk. The books show these three steps. I am trying to verify this by deriving from beginning to the end. The important thing is the boundary of the disk is ##r=a##. So the solution has to be finite when ##r=a## which rules out the easy solution of the few suggestions above.
It is given by the book:
This is my attempt:
[tex]=\frac{r^n e^{jn(\theta-\phi)}}{a^{n-1}}+\frac{r^{n-1} e^{j(n-1)(\theta-\phi)}}{a^{n-2}}+\frac{r^{n-2} e^{j(n-2)(\theta-\phi)}}{a^{n-3}}\cdot \cdot \cdot \cdot\cdot \cdot+\frac{r^2e^{j2(\theta-\phi)}}{a}+re^{j(\theta-\phi)}[/tex]
[tex]-\frac{r^{n+1}e^{j(n+1)(\theta-\phi)}}{a^n}-\frac{r^{n}e^{j(n(\theta-\phi)}}{a^{n-1}}-\frac{r^{n-1}e^{j(n-1)(\theta-\phi)}}{a^{n-2}}\cdot \cdot \cdot \cdot\cdot \cdot-\frac{r^3e^{-j3(\theta-\phi)}}{a^2}-\frac{r^2e^{j2(\theta-\phi)}}{a}[/tex]
As you can see, all except two terms get canceled out giving:
This is my attempt:
I cannot figure out what you are trying to do, but it does seem you are making the problem 100 times more difficult than it is. You want to evaluate
[tex]1+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)}+\sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{-jn(\theta-\phi)}<br /> = 1 + 2\, \text{Re}\left[ \sum_{n=1}^{\infty}\left(\frac{r}{a}\right)^n e^{jn(\theta-\phi)} \right][/tex]
The summation can be easily computed using
[tex]\sum_{n=1}^{\infty} x^n = \frac{x}{1-x}, \;\; x = (r/a)\, e^{j(\theta-\phi)}.[/tex]
Yes, you are correct, but this formula cannot accommodate when ##r=a##. This is a Laplace equation on a disk where boundary condition is ##r=a##. So this formula cannot be used.
So what? It can be used for all r < a, so you get a formula that is 100% correct for r < a. It is a separate issue altogether whether or not you can extend the answer to the case r = a. If you cannot, your beginning formulation must either be (i) applicable only to r < a; or (ii) in error somehow. There are separate issues that you are confounding, and that is leading to confusion on your part, or so it seems.
Anyway, if you do what I suggested you will get exactly what the book says. If you don't agree with the method and the answer, you are saying that you disagree with the book as well.
Ok, if you insist.
There is a common factor in the numerator of both fractions, can you locate it ?
montadhar said:
Ok, if you insist.
I know I can pull out ##\frac {r^{n+1}}{a^n}##. But that does not help to make the whole thing to zero.
It is NOT zero, and there is no reason why it should be. All you need is
[tex]\lim_{n \to \infty} \frac{r^{n+1}}{a^n} = 0[/tex]
and that is true if ##r < a.## Have you forgotten what is meant by the sum of an infinite series?
No I did not forget, I need to have the formula work for ##r=a##. This is the solution of Laplace with boundary condition at ##r=a##. You cannot say the OP was wrong from the book and only look at ##r<a##. Solution has to be continuous at the boundary.
Also, the method in the OP was suggested by the book. I just cannot cancel it out.
This is the copy of the book, it's for Laplace on a disk ##r=a## with boundary condition. Please ignore my writing.
166217[/ATTACH]"]
The method the book referred to in section 5.5 is as follow:
166219[/ATTACH]"]
166221[/ATTACH]"]
https://www.math.okstate.edu/~binegar/4263/4263-l15.pdf
look at Eqn 17, they indeed used the infinite sum of a geometric series.
I read through the article, but the article never address the issue of ##r=a## as I pointed out. The original formula
[tex]u=A_0+\sum_{n=1}^{\infty} \left(\frac{r}{a}\right)^n[A_n\cos(n\theta)+B_n\sin(n\theta)][/tex]
can accommodate ##r=a##, but not using the assumption of ##\sum_0^{\infty} x^n=\frac{1}{1-x}##
This formula has to be working with boundary condition, you cannot have undefined value on the boundary ##r=a##.
I just don't get this. Can you explain how you justify using this formula?
[tex][Acos(θ)+Bsin(θ)][/tex] is less than one ?
the entire term being less than 1 is what matters
