Solving SHM Spring Mass Homework Problem
  • Thread starter Thread starter laxbrah44
    Mass Shm Spring
The discussion focuses on solving a spring mass homework problem involving a spring with an unstretched length of 60.5 cm and a stretched length of 123 cm due to a mass. The period of oscillation was calculated as 1.58 seconds, but the user struggles to determine the mass, encountering negative values when using substitution. It is suggested to first find the spring constant K using the spring force of 88.7 N and the given information. Once the mass is determined, calculating K and the energy of the oscillation will be straightforward. The conversation emphasizes the importance of correctly applying the equations related to spring motion.
laxbrah44
A spring of unstretched length L0 = 60.5 cm and spring constant K is suspended vertically as shown. A mass m is attached to the spring and it stretches the spring to a length of 123 cm. Then the mass is pulled down an additional 8.74 cm from the equilibrium position and released. At its maximum deformation, the spring force is 88.7 N.
A. What is the period of the oscillation?
B. What is the mass m?
C. What is the spring constant K?
D. What is the energy in the oscillation?
kx=mg T=2pi(m/k)^.5 E= 1/2kA2
I found the period as 1.58s by doing (stretched - unstretched) / 9.8 and then sq root that then multiply by 2pi. However, I am completely lost on how to find mass. Using substitution, etc always gets me a negative number. Once I know how to get mass it'll be easy to find K and Energy. Thanks
You want to find k first. Use the info you were given in the last sentence.
