Solving Summation of sin with n^2 - Svensl
  • Thread starter Thread starter svensl
    Sin Summation
The discussion centers on solving the summation of sin with n^2, specifically the expression ∑(sin(2πn²Δ)/n) from n=0 to K-1. The user, svensl, attempts to rewrite the summation using complex exponentials but struggles to find a solution. Another participant clarifies that Δ is a number between 0 and 1 and suggests that as K approaches infinity, using a function with poles in the complex plane might help transform the sum into an integral via contour integration. The conversation highlights the challenges posed by the n² term and the potential of advanced mathematical techniques to address the problem.
svensl
Hello,
Can anyone give some hints on how to solve this:
\sum_{n=0}^{K-1}\frac{sin(2\pi n^2\Delta)}{n}
It's just the n^2 that complicates things. I tried re-writing it as
Im\sum_{n=0}^{K-1}\frac{e^{j n^2 x}}{n},
where x=2\pi \Delta
but I cannot solve this either.
Thanks,
svensl
Mathematics news on Phys.org
What is delta? If it is an integer than sin(2*pi*k) for any integer k is equal to 0.
Thanks for the reply.
Delta is a number between (0, 1(.
BTW, K will later be taken to infinity if that makes a difference.
Perhaps some well choosen function which has poles at certain places in the complex plane to give that summation as residues might be useful? Then you can use a contour integral and Jordans lemma to turn that sum into an integral along the Reals somehow?
That's without putting pen to paper so I might be way off.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
