Is the Triple Integral in Cylindrical Coordinates Correctly Solved?
The discussion revolves around the evaluation of a triple integral in cylindrical coordinates. Participants are examining the setup of the integral, specifically the description of the region of integration and the limits for the variables involved.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are questioning the correctness of the region E description, particularly the limits for r and z. There is also a discussion about the appropriate boundaries for integration, with some suggesting alternatives.
Some participants have offered corrections and confirmations regarding the integral setup. There appears to be a mix of interpretations regarding the limits of integration, but no explicit consensus has been reached on the final formulation.
There are indications of uncertainty regarding the boundaries of integration and the overall description of the region being evaluated. Participants are also navigating through potential corrections and clarifications without a complete resolution.
daphnelee-mh
(question is attached below)
x^2+y^2=r^2
dV=rdrdzdΘ
I am trying to solve it using cylindrical coordinates, but I am not sure whether the my description of region E is correct, whether is the value of r is 2 to 4, or have to evaluate the volume 2 times ( r from 0 to 4 minus r from 0 to 2), and whether is okay to take z from r^2/2 to 8
\int_2^8 dz \int_0^{2z} 2\pi \rho^3 d\rho
May I know which method did you use? I have no idea of it, thanks
Find attached my handwriting.
Shouldn't the boundary of integration be ##\sqrt{2z}## instead of ##2z##?
Yes. Thanks for correction.
Can you help to see whether this is correct ? Thank you
Yes it looks correct to me.
Thank you so much
The digits of 1008 add to 9, so...
daphnelee-mh said:
So 1008 is divisible by 3.
okay , thank you
  • · Replies 21 ·
  • · Replies 19 ·
