Solving Trigonometric Equations
  • Thread starter Thread starter frozonecom
    Trigonometric
2 replies · 2K views
frozonecom
[itex]2sin\Theta-\sqrt{2}=0[/itex]
[itex]2sin\Theta=\sqrt{2}[/itex]
[itex]\frac{2sin\Theta}{2}=\frac{\sqrt{2}}{2}[/itex]
So here's my problem. Should it be positive or negative? Or just positive? Since the square root of any positive number can be positive or negative, right? Is there a possibility that the answer can be both positive and negative?
[itex]sin\Theta=\pm\frac{\sqrt{2}}{2}[/itex]
if so, [itex]\Theta=45 degrees[/itex] [itex]or[/itex] [itex]135 degrees[/itex] ---- for positive value of [itex]sin\Theta[/itex]
[itex]\Theta=-45 degrees[/itex] [itex]or[/itex] [itex]315 degrees[/itex] [itex]or[/itex] [itex]225 degrees[/itex] ---- for negative value of [itex]sin\Theta[/itex]
So, I'm confused if:
Can be:
[itex]2sin\Theta-(\pm\sqrt{2})=0[/itex]
[itex]2sin\Theta=(\pm\sqrt{2})[/itex]
[itex]\frac{2sin\Theta}{2}=(\pm\frac{\sqrt{2}}{2})[/itex]
So can it be?
Is it mathematically correct to think of it that way? Sorry if this is such a stu*id question. :)
Hope you can help me! :)
[itex]\sqrt{2}[/itex] is positive and separate from its negative counterpart, [itex]-\sqrt{2}[/itex]. If the question did not say [itex]± \sqrt{2}[/itex], then you can safely just worry about the positive value.
If, on the other hand, the question was [itex]4sin^2 \Theta-2=0[/itex], then when you take the square root you must be sure to include the ±.
It is sort of like saying [itex]x=\sqrt{25}[/itex] is equal to positive 5 only, however if i said that [itex]x^2=25[/itex], then x could be +5 or -5.
Thank you for clearing this out for me!
Sadly that was on my quiz and I totally included the negative root as a solution for the equation. :(
At least now I know it. Thanks for answering! :)
