Some doubts regarding rotational dynamics
When a ball is tied to a string and rotated, the tension in the string is the only external force acting on it, which balances the gravitational force (mg) acting downward. The string creates an angle with the horizontal, ensuring that the net vertical force is zero. For an object in circular motion, the net external force acts toward the center of the circular path, providing the necessary centripetal force. The discussion highlights the relationship between tension, gravity, and circular motion dynamics. Understanding these forces is crucial for analyzing rotational dynamics accurately.
dreamz25
a) suppose we tie a ball with a string and rotate it keeping its other end tied with one of our fingers then the only external force acting on it is the tension. Which force then cancells 'mg' acting vertically downward?
b) if a mass is rotating in a circular path then in which direction does the net external force acting on it acts?
Not exactly sure what you are describing. But if you twirl the ball on the end of a string in a horizontal circle, the string will make an angle with the horizontal. The net vertical force will be zero.
What do you think?
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 32 ·
  • · Replies 27 ·
