Some simple integration (trig)
  • Thread starter Thread starter jwxie
    Integration Trig
The discussion revolves around solving two integrals: the first integral of 2x/(4+x^2) and the second integral of 3/(|x|√(x^6-1)). The first integral can be solved using a natural logarithm method, resulting in ln|4+x^2| + C, though some participants suggest exploring arctan as a potential method, which ultimately is not suitable. For the second integral, participants discuss similarities to the integral of sec and suggest making substitutions to simplify the expression. Trig substitution is mentioned as a possible method for the first integral, although ordinary substitution is deemed more efficient. Overall, the thread emphasizes the importance of exploring various methods for integration and understanding the nuances of different approaches.
jwxie
[1] integral of 2x / (4+x^2)
[2] \int \frac{3}{\abs{x}\sqrt{x^{6}-1}}
(the x above is absolute |x|, can't find the latex code...
[1] can be done easily using natural log method.
ln|4+x^2| +c
The reason I asked this was because this question belong to "The Caclulus of The Inverse Trig Functions", where it introduced how to take d/dx and integral of arcsin, arccos, arctan, etc.
I was wondering if [1] can be done by arctan... arctan = integral of 1/1+x^2
[2] It was very similar to integral of sec, integral of 1/ (|x| sqrt(x^2-1))
I tried to factor out those x and reduce it to x^3, but still no luck, because of |x|
Any help is appreciated.
Thanks
ln|4+x^2| +c
Sorry no, there's no "nice" way to express it in terms of the arctangent function. The book was maybe trying to show you that just because you see some (x^2 + a^2) term doesn't mean you should try x= a \tan t[/tex] straight away, but still check that the methods you used before don&#039;t work first. If they do, then use that!<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> [2] It was very similar to integral of sec, integral of 1/ (|x| sqrt(x^2-1))<br /> I tried to factor out those x and reduce it to x^3, but still no luck, because of |x|<br /> <br /> Any help is appreciated.<br /> Thanks </div> </div> </blockquote><br /> Your hunch is good. So if you want to make the integral you have now look like the one for arcsec x, what substitution could you make that does that? With experience you will learn that when you want to make two algebraic expressions &quot;similar&quot; enough for a u-substitution, the best things to make the same is what&#039;s under the root sign, and hopefully the rest will fall into place.
jwxie,
Don't omit the dx in your integrals. If you do, you can run into problems, especially in trig substitutions.
Gib Z,
Regarding \int \frac{2x dx}{4 + x^2}
this can be integrated using trig substitution. This is not the most efficient way to do things, because an ordinary substitution is quicker for this integral, but a trig substitution works and isn't much more involved.
Using an ordinary substitution, u = 4 + x2, and du = 2xdx, you arrive at an antiderivative of ln(4 + x2) + C
Using trig substitution, with 2tan w = x, and 2sec2 w = dx, you arrive eventually at an antiderivative of ln( (4 + x2)/4 ) + C'.
These antiderivatives appear to be different, and they are, but they differ only by a constant, namely ln(4).
Hi.
Thank you both of your helps. I understood them now.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 22 ·
