Space and Earth's (and other planet's) movement through it
  • Thread starter Thread starter Menaus
    Movement Space
Menaus
My question stems from the idea from GR, that space is a physical quantity bended by gravity. The question is this:
If space be a tangible, physical, thing, in which gravity effects it, among other things, then shouldn't the Earth's movement(and the movement of other bodies) be dragged by this space? Additionally, we have dark matter and dark energy, both of which are masses which should impede Earth's movement along its orbit.
Are space, and dark matter and energy, so insignificant that they are essentially moving through the Earth? Or do they drag as the Earth moves through all of it? Or a combination of both?
The idea that space is a "thing" is one of those intuitively appealing analogies which only serves to mislead. Space does not behave like something tangible, and there is nothing to be gained from imagining that it does. It does not have any of the properties of a material thing.
If you say that space is "bent and stretched" by gravitational fields, then what are its elastic coefficients? :smile:
Likewise the terminology "frame dragging" does not imply that space is viscous! If the analogy held, one could imagine that frame dragging would cause the Kerr solution to slow down and eventually come to a stop. :wink:
Well, often we try to apply properties to space, this tends to indicate that indeed it is a 'thing', because otherwise we would be applying properties to that which doesn't exist.
Read Hume's treatise on Human Knowledge. Within, it is said that space has properties which can be measured, therefor space is physical. If it wasn't a 'thing' we wouldn't be able to measure it. I don't see what bars us from the idea that space is some sort of physical entity, as much in the Standard Model seems to imply it.
The curvature of spacetime influences the motion of objects, but you shouldn't imagine that space exerts any sort of "drag" on objects. For one thing, this would violate the principle of relativity, which tells us that objects in uniform motion through space are allowed to regard themselves as being at rest, with the rest of the universe moving around them. Objects at rest certainly shouldn't feel any drag from space, so objects in motion shouldn't either.
Dark matter shouldn't offer any appreciable resistance to the Earth's motion because it is supposed to pass right through regular matter most of the time.
Dark energy is much more mysterious. It may just be an extra term in the equations of GR that influences the evolution of spacetime. Such a term would not exert any sort of drag on Earth's motion through spacetime.
If you want to call space a "physical entity," that's fine. Just don't get misled by the phrase "physical entity" into thinking that space should cause some drag on motion, or something like that. It doesn't. By your definition, a "physical entity" is just "something with measurable properties" and that does not imply that a "physical entity" has to have *familiar* properties like drag or friction.
Spacetime has the familiar property of "curvature" but none of the other properties of material things, like friction, viscosity, elasticity, hardness, density, inertia, mass, speed, momentum, color, or opacity. This is why Bill_K wants to discourage you from thinking of spacetime as a material thing.
Menaus, This forum is for the discussion of physics, not philosophy. If you want to expound on David Hume and his opinions about the properties of space, please do it elsewhere.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
