Space Stuff and Launch Info
1,685 replies · 208K views
Daylight pictures (very high resolution, zoom in!)
The launch pad is a big mess of steel from the collapsed tower, remains of the transporter/erector and soot. The rocket is just gone. Looks like the integration facility (big white building) is fine overall but the tents near it are damaged. Not sure why the next booster is outside.
Yield estimates are somewhere from 1000 to 3000 tonnes of TNT equivalent total, although not everything reacted simultaneously so it wasn't as destructive as a single explosion with that yield. It's in the top 10 largest unplanned explosions in history.
Discussion of impact on US spaceflight
If this is an engine problem then Vulcan is affected, too. If it was caused by the ground infrastructure then Vulcan can fly again once it solved its booster issues. Either way, for now SpaceX is the only one with available medium- and heavy-lift launch capability (ULA can fly its remaining Atlas rockets but they are all booked out).
Reply
That's a big dent in the tower that's still standing. They probably have to rebuild that as well. Even if something looks like it's still intact, it could have taken internal damage from the explosion, making it weaker and more likely to fail later. All the exposed plumbing can't be trusted any more.
Someone combined explosion footage with an estimate how fast Dragon's escape system would have moved away from it: Video
It's probably the worst-case scenario in terms of how late it launches, but it still avoids the fireball.
Reply
Surprise maiden launch of Long March 12B. No announced launch date, no hazard areas for aircraft to avoid, it just launched.
This rocket is designed to reuse its booster in the future, but the first flight made no recovery attempt. The launch was successful.
Good news from Blue Origin. They can repair the damaged tower and the more complicated infrastructure is still fine. They plan to launch again this year. That probably means early next year but it's still quick for a massive launch pad explosion.
Update on SpaceX's computing satellites
16:00 shows the satellite concept with some numbers. Around 2 tonnes per satellite, 120 kW average computing power. Two large solar panels, a central computing point and then some smaller radiators.
Google pays SpaceX $0.9 billion/month for ~250 MW of Colossus if I understand the numbers right, assuming the satellites are as effective as computing on Earth and assuming that rate will stay the same then each satellite could generate $0.9 billion/month * 120 kW/(250 MW) = $400,000/month in revenue, or $200,000/month per tonne of payload. SpaceX launches their own payloads for around $1000/kg so even on Falcon 9, launch costs would only need 5 months to recover, and the rest goes into building the satellite and then profit.
Amazon got a complete waiver for its Leo constellation deployment speed.
Originally they had to deploy 50% of the constellation by the end of July 2026 and the full constellation three years later. They are currently at 10%. The 50% deployment milestone is gone. They can apply for a waiver or delay of the 2029 deadline in the future.
Artemis III crew announcement
Randolph Bresnik (previously flew on the Space Shuttle and Soyuz)
Luca Parmitano (ESA, previously flew two Soyuz missions)
Francisco Rubio (previously flew a Soyuz mission) - no relation to Marco Rubio as far as I can tell
Andre Douglas (no flight yet) - was already backup for Artemis II
Artemis III will stay in Low Earth orbit. The plan is to dock with a Starship that has a docking adapter, but it looks like it won't have anything else. Practice approach and docking, fly around Earth to test Orion in more detail, then land again.
I missed some earlier discussion, I think they also announced some plan changes to Artemis IV (i.e. the Moon landing). Will update this post later.
Edit: At 26:00. Starship and Orion will dock in Earth orbit, Starship will fly both to low lunar orbit. It moves the critical docking maneuver to Earth orbit, it saves Starship propellant, and it means the crew can return much faster in an emergency as low lunar orbit has a much shorter period than the original NRHO plan.
Reply
China Manned Space Agency (CMSA) has approved a plan to use the Lijian-2 rocket as the upper stage and the Long March 10A as the first stage (booster stage) to launch navigation satellites into lunar transfer orbit (LTO), or trans-lunar injection (TLI), in mid-2026, Chinastarmarket.cn reported, citing Lian Jie, deputy chief engineer of the Lijian-2 program.
This will be the first mission for Long March 10A, signaling a clear push to accelerate China’s crewed lunar mission. Besides, the mid-2026 launch will mark the first time a commercial Chinese firm’s rocket enters cislunar space – the area “on this side of the Moon” where Earth and Moon gravity interact.
Source:
https://asiatimes.com/2026/04/us-china-space-race-shifts-into-a-higher-lunar-gear/
Reply
Reply
SpaceX developed "Starfall", a set of disk-shaped reentry vehicles. They are essentially a heat shield, parachutes, and some basic maneuvering capability to reenter in the right orientation. Each one has a mass of 2 tonnes and can reenter with up to one tonne of payload.
The first demonstration mission is planned to launch on Tuesday (Jun 23 2026, 10:43 UTC, in 1 day and 7 hours). Three tonnes would be a very light payload for Falcon 9 but I haven't seen any indication that they would launch more than one. I also don't know when the capsule is expected to reenter. It'll target the Pacific near the West Coast. SpaceX has a lot of experience with reentry so they probably didn't have any issues getting a license for that. Reentry after just a bit under one orbit would be the most natural approach but maybe they want more time in space before returning to Earth.
Starfall can be used to manufacture things in space and return them, or maybe deliver some extremely important thing to some remote place faster than an airplane (realistically, only the military would pay enough for that option). There are a few companies working on drug manufacturing in space in particular. Booking a flight on an already existing reentry capsule could reduce development cost for these companies.
The Neil Gehrels Swift Observatory is a gamma ray telescope launched in 2004. The spacecraft is still healthy, but drag has reduced its initial 600 km orbit to 370 km, with reentry expected for the end of the year.
Katalyst Space Technologies won a contract for a last-minute rescue mission, which is scheduled to launch in three hours from now. It looks like there won't be a livestream. The rescue spacecraft is expected to reach Swift in 3-4 weeks and boost it to around 600 km, which is enough for at least ten more years. Docking with a telescope that wasn't designed to be serviced can be tricky, we'll see if it works.
The mission is using the last Pegasus XL, an air-launched rocket that is no longer competitive - it costs almost as much as Falcon 9 but with only 3% of its payload. After this launch there will be no operational air-launched orbital rocket. Some companies are developing new systems.
Reply
The Swift rescue mission launched now. The launch was successful, but we might not hear more until it docked (or attempted to).
The last conventional Atlas V launched another batch of Amazon Leo satellites. There are six Atlas V remaining but they are all a different configuration that is reserved for Starliner.
Reply
I heard about this last Friday.
CAPE CANAVERAL, Fla. (AP) — A three-armed spacecraft rocketed into orbit Friday to rescue a NASA telescope that’s in danger of crashing back to Earth.
Northrop Grumman launched Katalyst Space Technologies’ Link spacecraft from the Marshall Islands in the Pacific. The Pegasus rocket blasted off from the belly of a modified airplane, putting Link on course to reach and capture NASA’s Swift Observatory in about a month.
Launched in 2004, Swift is sinking faster than ever because of recent solar storms. NASA is paying $30 million for Katalyst to capture the telescope and boost its orbit . . .
https://apnews.com/article/swift-nasa-satellite-rescue-katalyst-a7ddd740ca099587c58865f583c7245a
If all goes well, Swift could be back scanning the cosmos by September.
The 1.6-ton (1.4-metric ton) Swift currently is circling 224 miles (360 kilometers) above Earth. Katalyst aims to raise the telescope’s altitude by 150 miles (240 kilometers), back to where it all began. Link’s thrusters will fire to boost Swift slowly, so there’s no heavy jostling.
If all goes well, apparently there is consideration to apply the technique to boost Hubble, which also has a decaying orbit because of increased atmospheric drag caused by the sun’s outbursts.
Teams have successfully established communications with Katalyst Space’s robotic servicing spacecraft LINK, which is designed to raise the orbit of NASA’s Neil Gehrels Swift Observatory to a higher altitude.
https://science.nasa.gov/blogs/swif...act-with-spacecraft-set-to-boost-nasas-swift/
From NASA - https://science.nasa.gov/mission/swift/swift-boost-mission/
NASA has contracted Katalyst Space of Flagstaff, Arizona, to boost the altitude of its sinking Neil Gehrels Swift Observatory. Swift is NASA’s astrophysics multitool, capable of quickly observing a wide range of cosmic objects in visible, ultraviolet, X-ray, and gamma-ray light.
This July, Katalyst’s LINK robotic servicing spacecraft launched into orbit aboard a Northrop Grumman Pegasus XL rocket, to attempt to capture and raise Swift over the course of several months.
All spacecraft in low Earth orbit experience slight drag from our planet’s atmosphere. If they don’t have propulsion systems to maintain their orbits, the drag gradually reduces their altitudes. A recent bout of solar storms magnified this effect on Swift, which began to sink faster than anticipated.
NASA awarded Katalyst the contract in September 2025, so the company had less than a year to design, build, test, and launch a spacecraft to meet, grab, and lift Swift. In the meantime, teams at NASA’s Goddard Space Flight Center in Greenbelt, Maryland, and Pennsylvania State University’s Eberly College of Science in University Park made innovative operational changes to keep Swift at least 185 miles (300 kilometers) above Earth, where the boost mission has the best chance of success.
While NASA could have allowed Swift to re-enter the atmosphere, the situation presented an opportunity to demonstrate a key capability for the future of space exploration. This daring approach also extends Swift’s scientific lifetime and is more affordable than replacing the observatory’s unique capabilities.
Reply
Ars Technica also brought a piece on the Swift boost:
https://arstechnica.com/space/2026/...cue-mission-is-now-in-pursuit-of-nasas-swift/
“Over the next several weeks, Katalyst will perform checkout procedures for Link, including assessments of its propulsion, sensor, and navigation systems,” NASA said in a statement. “Link will then approach Swift and complete a survey of the 21-year-old observatory, before capturing and lifting it over the course of several months.”
Hubble was designed for docking, a mission there is much easier.
Starship flight 13: No earlier than July 14
This looks very optimistic as the booster hasn't made a static fire test yet, but it means we can expect a launch soon. July 22 would make it two months after flight 12.
13 will repeat the flight profile of 12. If successful, 14 might go to orbit, maybe even with both booster and the first ship catch attempt.
Edit: Moved by a day, no earlier than July 15.
SpaceX found a secondary customer for Falcon 9 booster flights. Besxar will test semiconductor fabrication in vacuum and microgravity during the few minutes where the booster is in free fall. The upper stages will fly their normal missions.
HELSINKI — China is set for a debut flight of its Long March 10B rocket in July and attempt to recover the first stage at sea.
Recently issued airspace and maritime warning notices indicate that the first Long March 10B reusable rocket, to launch from Hainan Commercial Space Launch Site, Hainan island, now has a launch window opening July 10, running between 1:00 a.m. and 5:00 a.m. Eastern (0500-0900 UTC), with repeat daily windows scheduled through July 13.
Source:
https://spacenews.com/china-schedules-long-march-10b-rocket-launch-and-recovery-attempt/
They caught the booster!
Video
The landing profile looked a bit odd to me, with the booster being almost stationary before suddenly dropping again, but maybe that is intentional. Also, the interstage looks really toasty.
That makes China the second country, and third entity (after SpaceX and Blue Origin), to land the booster of an orbital rocket. We'll see if this one can be reused or if they need some more work before reusing future boosters.
25 second static fire of the Starship booster. This is a new booster, and they immediately went to do the longest booster static fire ever.
The video taken from above is slowed down, making the shockwaves easier to see.
SpaceX released the second part of its documentary: Critical path
Hayabusa2 flew past asteroid 98943 Torifune, at a distance of under a kilometer, with a relative velocity of 5 km/s. It only spent ~200 milliseconds in its closest approach phase, and it took a good picture of the asteroid.
It wasn't designed for that in any way. The mission was built to slowly approach and land on an asteroid and return samples to Earth - something it did in 2020. Everything else since then has been an extended mission. If it's still working by then, it will visit an asteroid with a diameter of just 11 m in 2031.
https://en.wikipedia.org/wiki/File:TorifuneHayabusa2.png
Edit: JAXA joins the hopper tests for reusable rockets
More edits: Page for Starship flight 13
A repetition of flight 12. They confirmed that the booster was lost from an unexpected flip direction.
They will deploy real Starlink v3 satellites which will try to connect to ground stations and other satellites (via laser links) in the short time they have in space. They'll reenter over the Indian Ocean just like the ship.
Reply
The Starship Flight 13 mission is expected to launch no earlier than 6:45pm (local time) today.
Space Flight now coverage.
If all works out, this Starship will deploy 20 V3 starlink satellites.
A Falcon 9 upper stage will hit the Moon on August 5.
This stage launched Firefly's Blue Ghost Mission 1 to the Moon (the first fully successful commercial landing), so it was left in a high Earth orbit that came close to the Moon. Ejection from Earth orbit, hitting the Moon and hitting Earth were all possible outcomes, we now know it's going to hit the Moon.
There have been a few impacts of rocket stages on the Moon before, some of them planned, but they are relatively rare. These impacts release material from below the surface so astronomers are now preparing to watch the event. It'll be in sunlight, only visible with telescopes. The ~30 meter crater it produces should be visible from spacecraft orbiting the Moon. The stage will also fly past a Korean spacecraft at a distance of just a few kilometers, which might lead to some opportunity to observe it before impact.
Reply
Starship launch in 8 minutes
Edit: It's swimming! It hovered above the ocean as planned, then tipped over. It was expected to blow up from impact, but this one survived. Drones are getting great detailed views of the heat shield now.
The booster didn't relight enough engines for the landing burn and hit the ocean at a higher than expected speed. Still needs some work there, but the ship part was flawless.
Edit: The next flight is expected to go to orbit and attempt a ship catch if they don't find any issue in the detailed analysis.
Reply
Some of those shots are not just from the drones - but from the onboard cameras that survived and are continuing to broadcast while the ship bobs in the water. The ship is mostly empty of fuel - so it is floating very high.
It will be interesting to see how long it will continue floating. As long as those tanks stay pressurized, I don't imagine that it will take on much sea water.
Reply
