Spark generation in capacitors
The discussion centers on the phenomenon of spark generation when connecting the plates of an ideal charged parallel-plate capacitor. Participants clarify that a spark can occur due to dielectric breakdown, which is similar to lightning, and is influenced by the electric field strength between the plates. When the plates are brought closer, the electric field increases, potentially leading to a spark before contact. The conversation highlights the distinction between ideal and real capacitors, emphasizing that imperfections in real capacitors can contribute to spark generation.
  • Understanding of dielectric breakdown and electric fields
  • Familiarity with parallel-plate capacitor theory
  • Knowledge of potential difference and its role in spark generation
  • Awareness of real versus ideal capacitor characteristics
  • Research dielectric breakdown mechanisms in capacitors
  • Study the impact of electric field strength on spark generation
  • Explore the differences between ideal and real capacitors
  • Learn about the effects of charge distribution in capacitors
Electrical engineers, physics students, and anyone interested in capacitor behavior and spark generation phenomena.
hokhani
If we directly connect the two plates of an ideal charged parallel-plate capacitor, a spark will generate. What is the exact reason of spark?
If by "connect", you mean that you let the two plates touch each other, then I have 2 comments:
1. Shouldn't you create a short by touching them together? If this is the case, why would there be "sparks"? You may get sparks as they both get closer, but not after they touch!
2. A spark can happen even when they are not touching. That's how you can destroy a capacitor.
This "spark" is a dielectric breakdown in the capacitor, similar to lightning in air. The exact mechanism is complicated, and one may even argue that this is similar to a vacuum breakdown.
Zz.
Likes anorlunda
Zz.
In an ideal parallel-plate capacitor, the electric field between the plates is always constant no matter in which distance they are. Why the dielectric breakdown occurs when we make them closer while it doesn't occur when they are far?
This doesn't make any sense. If your capacitor is connected to a constant voltage source (i.e. batteries), then when you make them closer, the electric field in between the plates increases (E = V/d), since the separation distance "d" gets smaller. So your claim that the electric field is always a constant when the distance between them changes is wrong.
Zz.
Zz.
Please consider the case where the plates are disconnected from the battery. In this case, the electric field is always constant.
Zz.
By this, do you mean that short circuiting the plates never cause spark and spark is only due to dielectric breakdown?
I think that by shorting the plates, the electrons gain high acceleration and so there will be great radiation that we observe as spark. Is this right?
When you short circuit the plates, the current goes through the contact point, not through the gap. So what spark?
You asked me if it is right based on something you contradicted with what I said. So why should I tell you that it is right, when you are going against what I told you?
Zz.
Doesn't make any sense either. If the battery is disconnected, then the amount of charge is fixed on each plate. Now what do you think will happen if the spacing gets closer?
You seem to be making things up as you go along. You never specified this when you started the thread. And now, you're changing your tune. I don't want to play this game anymore.
Zz.
Perhaps hokhani is thinking of something other than an ideal parallel plate capacitor - i.e. a real one. In an ideal parallel plate capacitor with a fixed charge distributed evenly across the plates right to the edges, the field is constant. V = Ed, so as the plates approach, V⇒0 (potential energy of charge ⇒ 0) and no sparks. But in a real capacitor surfaces will not be completely smooth (say, ± δ). So that as the plates approach and the separation d → δ, the charges will move around and accumulate at the closest point, increasing the electric field (E) at that point which could cause a spark before they touch.
AM
Andrew Mason said:
Perhaps hokhani is thinking of something other than an ideal parallel plate capacitor - i.e. a real one. In an ideal parallel plate capacitor with a fixed charge distributed evenly across the plates right to the edges, the field is constant. V = Ed, so as the plates approach, V⇒0 (potential energy of charge ⇒ 0) and no sparks. But in a real capacitor surfaces will not be completely smooth (say, ± δ). So that as the plates approach and the separation d → δ, the charges will move around and accumulate at the closest points, which could cause a spark before they touch.
AM
But the problem here is that in the very first post, there IS a spark! That appears to be the central question, i.e. why is there a spark? If there is no spark, this question does not exist, does it?
During winter or when the air is very dry, we sometime get a jolt when we are about to touch a door handle or a metallic object. This happens when we get very close to it, but NOT when we actually touched it. In fact, touching something metallic is one way to prevent this from happening again soon. The OP never provided any evidence for the observation of "ideal parallel plate capacitor" having a spark when they are "directly connected". If this actually happened in real life, this is not an "ideal parallel plate capacitor". So this whole premise in this thread is full of contradictions, and the OP seems to making it up as he/she went along.
It was why I decided to disengage from answering his queries anymore.
Zz.
well ... shorting out a capacitor does produce a spark ... have done it many, many times over the years in the workshop
But I haven't looked at it on the microscopic level to see when the spark occurs
A 100V 10uF electrolytic cap will produce a healthy spark and "crack" sound when the terminals are shorted out by a screwdriver
and will leave burn marks on the cap terminal and on the screwdriver tip.
Assumption is that there must be a gap for a spark to occur ?
if so, the gap must be really small in that it is impossible to tell doing a quick experiment whether the spark occurred
with micrometres between the 2 conductors or at the time of contact ?Dave
Indeed, agreed, at the voltages involved, 5000V and much more, the gap is easily seen as is the spark jumping across those several mm.
But with a screwdriver etc across a capacitor, the gap isn't obvious and it is easy to understand
that people possibly mistakenly think it happens at the point of physical contactDave
Bringing a conductor across the capacitor leads is a very different scenario than the OP's scenario of bringing the plates physically close together.
The charge on a charged capacitor plates creates a potential difference, V, between the plates and, therefore, between the leads. V does not change if you change the distance between the leads. So, if V is high enough and if you then bring the leads close enough together, you are going to create an E field that exceeds the dielectric breakdown strength of the air creating a spark.
On the other hand, if you move the plates together (in an ideal parallel plate capacitor), the E field is constant so V approaches 0 as the plate separation approaches 0 → hence no spark.
aM
First, let's go back to what we know:
1. If there is no potential difference, there will be no spark. So when something is shorted, after the potential difference has dropped, breakdown can't happen.
2. A screw driver touching a capacitor is not an ideal capacitor.
This is where careful consideration has to be done on what exactly what happened. Did the spark occurred right before contact? Or did it continue a millisecond second or two after contact? Here's the issue, and I've sketched a particular scenario here:
When you first make contact with the plate with another grounded object, the capacitor since won't be fully discharged immediately. The contact point often has a high resistance, and so the time constant for discharge isn't 0. There is still a momentary potential difference between the plate and the rest of the object during discharge. I illustrate 2 points where the potential difference can easily cause further arcing, especially if the object has other sharp points or corners.
So the arcing is in between the two due to the large electric field developed over a small distance.
Zz.
but it's unlikely to be instantaneous, as in, the discharge occurs over maybe milliseconds
as you indicate in what I quoted from you below. So doing that short isn't an instant voltage drop
it occurs over a brief period of time allowing for that arc generation ??
great response and it goes towards explaining my own ponderings that I was trying to put into words in my previous posts
thanks :smile:
  • · Replies 16 ·
  • · Replies 103 ·
  • · Replies 21 ·
