Special relativity - frame of reference
The discussion centers on the twin paradox in special relativity, specifically addressing the aging differences between two twins, Bob and Alice, when one travels at high speed. Bob's frame of reference is non-inertial due to acceleration, while Alice remains stationary, leading to Bob experiencing time dilation and returning younger than Alice. The key conclusion is that the twin who accelerates (Bob) takes a different path through spacetime, resulting in a measurable difference in aging when they reunite. The discussion emphasizes that biological aging is not merely a mechanical clock but is influenced by the relativistic effects of motion and acceleration.
  • Understanding of special relativity principles
  • Familiarity with time dilation and spacetime concepts
  • Knowledge of inertial vs. non-inertial frames of reference
  • Basic grasp of the twin paradox scenario
  • Research the implications of time dilation in high-speed travel
  • Explore the concept of spacetime intervals in special relativity
  • Study the effects of acceleration on time perception and aging
  • Investigate experimental evidence supporting time dilation, such as cosmic ray muons
Students of physics, educators teaching relativity, and anyone interested in the implications of special relativity on time and aging.
  • #31
richrf said:
Are you saying that real biological aging is dependent upon clock measurements?
They are the same thing! Have you ever seen hair get shorter? Fewer wrinkles? Your nails shrink? Does your heart undo a few beats? If not, all these processes are useable as rough and ready clocks.
Edit: it's all just chemistry when you get down to it.
  • #32
richrf said:
Had this idea been tested?
We can't measure biological aging precisely enough to confirm, for example, that astronauts who spend extended periods on the International Space Station age slightly less than people who remain on Earth.
However, there are plenty of experiments to show that all processes involving change that we can measure precisely enough are affected by their paths through spacetime in precisely the way that SR and GR predict. The GPS system is the most commonly known example of such an experiment; if SR and GR were not correct in their predictions, GPS would not work.
  • #33
richrf said:
When is a human or any biological entity actually been used as a clock?
You mean like a birthday party? It's the child's 5th birthday today, so if you wanted to know what year it is on the day of the party you can just add the child's age to his birth date.
The entire example presented depends up experimental evidence that biological life is a clock. Lacking that, then humans have to be removed from the example and substituted with clocks for which there is evidence.
If that's your objection then remove the humans from the example and create an example that doesn't involve humans. The physics is the same, either way.
When you state a person's age what you are really doing is declaring the amount of time that has elapsed since their birth. Are you claiming that mechanical clocks can't be used to measure that amount of time?
  • #34
PeterDonis said:
Real biological aging is governed by the same thing that governs clocks--proper time along your path through spacetime. So are all other processes involving change.
Would you say this is scientifically proven? Can you point me to a paper on this subject with experimental evidence. I am trying to separate ontological, philosophical speculation from scientifically established evidence.
  • #35
This is very interesting and addresses my question, which is solely about biological aging. Can you explain or direct me to a paper that describes how it was determined that someone biologically aged less in space than they would have if they were on Earth? This would be an extremely interesting read. Thank you.
  • #36
I am differentiating between measured aging and real biological aging, as in the case of twins.
  • #37
Can you point to any evidence at all that aging is a non-physical process? One that doesn't depend on chemistry and, therefore, ultimately on quantum theory? If you can't, why would you imagine it obeys different physical laws from everything else?
That would seem to be the extraordinary claim here.
  • #38
I am simply asking for evidence that biological aging is affected as is being suggested. I don't believe there is any laws of chemistry that can be used to support this claim. I'm not one to leap without strong evidence and theory.
  • #39
You are wrong. Biological bodies are physical objects. Physical objects obey the laws of physics. The laws of physics, which have been confirmed extensively for objects whose "aging rate" we can measure precisely, say that all objects age according to proper time along their path through spacetime.
Then you are the one who is making a claim without evidence. What evidence do you have that "real biological aging" is not a physical process like any other?
  • #40
It's really quite simple. All physical processes must run slow by the same factor, as measured by an observer in relative motion, or relativity is trivially and wildly wrong. I already pointed out the evidence that it is not wrong, in the sticky at the top of this forum. So either aging runs slow or it is not a physical process.
  • #41
Thank you all.
  • #42
I need to read more to understand this. Is not clear to me why acceleration makes the differece but I guess is to soon to ask you here, I'll read some more and if I still don't get it I'll ask you.
Thank you.
  • #43
Thank you.
It doesn't; it is just used to explain how the relative velocity (which does make a difference) is achieved. Draw a spacetime diagram. You will know you have understood it properly when you say to yourself something like "this is just Pythagoras with the sign changed".
  • #44
Acceleration doesn't make a difference. The path length through spacetime does. The only place acceleration comes in is that you need the paths to cross twice to compare lengths, and in flat spacetime that means one needs to turn round.
  • #45
I guess it would be Hafele–Keating experiment
  • #46
PeterDonis said:
You are wrong. Biological bodies are physical objects. Physical objects obey the laws of physics. The laws of physics, which have been confirmed extensively for hi whose "aging rate" we can measure precisely, say that all objects age according to proper time along their path through spacetime.
Aren't you asking a philosophical/metaphysical question, or has physicalism be proven as a scientific fact? I'm not asking about philosophical viewpoints, I am asking for scientific evidence.
  • #47
Thank you, but I do not believe this addresses my question. I am specifically interested in the experiment that demonstrated that astronauts returning from space aged less than they would have if they remained in Earth. This is the claim that I would like to read about.
  • #48
They age according to the journey time. The journey time is understood. You need to justify why you think they would age differently than their clocks!
  • #49
I am looking for evidence that biological aging is dependent upon clock measurements. If there isn't any, then that would end my inquiry.
  • #50
Not in any meaningful way you aren't. Whether one uses "measured aging" or "real biological aging" one gets the same answer. On my 50th birthday the "measured aging" is 50 years, and the "real biological aging" is 50 years. You have a distinction without a difference.
  • #51
I already gave you an answer as regards astronauts: we can't measure biological aging precisely enough. So if that's the only evidence that will satisfy you, it doesn't exist.
  • #52
Two twins can be measured to be of different ages, but are biological the same age, e.g. both have gray hair and aged skin. The question is whether clock measurement observations determine the biological aging process?
  • #53
No, and no. You can't "prove" physicalism. So if a proof of physicalism is the only thing that will satisfy you, it doesn't exist.
However, if such proofs are the only thing that will satisfy you, further discussion of the issues you are raising here is pointless, since you refuse to accept reasonable arguments based on the evidence we do have--the same reasonable arguments that convince everybody else that, if you send a clock along with an astronaut, the astronaut ages at the same rate that the clock ticks. And clocks, whose elapsed times we can measure precisely enough, have indeed been sent on the same kinds of trips that astronauts have, and the elapsed times on the clocks match precisely the predictions of GR. All of this is strong indirect evidence that biological aging goes at the same rate as everything else. If you are unwilling to accept that, then, again, further discussion is pointless.
  • #54
Thank you. Can you provide me with a link describing the case of the astronauts. Presumably they were able to determine how to measure biological aging in a spacecraft vs. remaining in Earth. This is what I am most interested in.
  • #55
You can't measure biological age precisely enough by things like gray hair and aged skin. People vary a lot in when, during their biological aging, they develop such features. As I've already said, we do not have any way of measuring biological aging precisely enough to directly test for differences between people who follow the kinds of paths through spacetime that we can achieve, such as astronauts spending extended periods in low Earth orbit as compared with people on Earth--or even astronauts going to the Moon or Mars as compared with people on Earth. All of the elapsed time differences in these cases, as measured by very accurate clocks, are extremely small--from a few parts per billion to at best a few parts per million. We have no way of detecting differences that small in the biological ages of people or other living things.
  • #56
Did you even read my posts? I have said several times that we cannot measure biological aging that precisely.
You are now banned from this thread since you are evidently unable or unwilling to address the actual points others are making, or even read them.
  • #57
@richrf - I already showed you a way to directly link aging to clock measurements. You have a clock whose pendulum will crash into a gate and stop if the gate is closed. You open and close the gate rhythmically based on some biological process like your heartbeat, and the clock keeps running because the gate is always open just when the pendulum needs to pass. But according to relativity, any observer may consider themself to be at rest, so you, your heart, and the clock are moving at different speeds according to different observers. Thus your heart rate must slow the same amount as the clock, or else observers would disagree about direct observables like "is the clock running", "did you hear a clang from the pendulum hitting the gate".
The only way out of that is to assume that relativity is fundamentally wrong: there is some privileged frame where mechanical clocks and biological clocks tick at the same rate, but they don't in others. I'm not sure the concept really makes sense, though, since we're left wondering what two clocks that aren't synchronised but aren't wrong are even doing. How are they both clocks? And anyway, since Michelson and Morley in the 1890s we've been failing to find evidence of such a privileged frame.
Then there's the point that all macroscopic structures are made of atoms. And atoms, we do know, obey relativity (the Hafele-Keating experiment). So claiming that biological systems don't do so is a bit like the claims perpetual motion machine designers make - every component part can be shown easily to obey conservation of energy, but somehow you can combine them and they don't. Similarly, every part of a biological system is made of atoms that obey relativity, but somehow the combination doesn't. Is that at all plausible?
We have not done a twin paradox with real twins, no. We can't accelerate them to the speeds needed to see anything with a clock as imprecise as "how much grey hair do I have". But why would you expect a special exception to physics for biological systems?
  • #58
No, that's not possible, as far as I know. Do you have a reference that supports this claim?
Clock measurements do not determine the biological aging process, but clock readings do measure the biological aging process.
  • #59
All, please be aware that @richrf has been thread banned, so he cannot respond to further posts.
  • #60
Acceleration, by itself, doesn’t make the difference. However, it does break the symmetry.
Relativity, like a lot of modern physics, is largely about symmetries. The principle of relativity, in particular, is talking about a symmetry between inertial reference frames.
An inertial reference frame is one where Newton’s first law (inertia) holds: an object not subject to any force moves in a straight line at a constant velocity. If you draw a spacetime diagram in such a frame, then inertial objects are represented by straight lines. There are many different inertial frames, but anything that is a straight line in one is a straight line in any other. Conversely, anything which is a bent line in one inertial frame is a bent line in any other. Bent lines in spacetime represent objects which are accelerating.
The principle of relativity asserts that all inertial frames are equally valid. That is a symmetry principle. But the traveling twin experienced acceleration so his worldline is bent in any inertial frame. But when we talk about “his frame” we specifically mean a frame where his line is straight and at rest along the t axis. So this frame cannot be inertial, and so the symmetry is broken, and his frame is not equivalent to an inertial frame.
  • · Replies 55 ·
  • · Replies 25 ·
  • · Replies 47 ·
  • · Replies 57 ·
  • · Replies 87 ·
  • · Replies 33 ·
  • · Replies 29 ·
  • · Replies 67 ·
