Spectrophotometry: Iron in Vitamin tablets and Absorbance
  • Thread starter Thread starter MitsuShai
    Absorbance Iron
9 replies · 12K views
MitsuShai
This is the experiment that I did in class, please read the whole thing before posting:
http://www.chem.uic.edu/fetzer/chem222/Exp_19.pdf
How do I calculate the molarity of Fe(o-phenanthroline) in each solution?
So I was thinking of doing this:
According to the pdf there are 2.5 grams of o-phenanthroline dissolved in 100 mL of ethanol and 900 mL of water was added, but I don't know the moles of o-phenantroline.
For the standard Fe: .04 mg/mL, I can find the mg of Fe of each solution
.04 x 10 ml= .4mg
5mL= .2 mg
2 mL= .08 mg
1 mL= .04 mg
and from the periodic table table we can find the moles of Fe
So I'm wondering if I can find the molarity of Fe(o-phenanthroline) from the absorbance because I don't see how else to find it.
Here's my data:
Micrograms of Fe Standard (mg)
0.2
0.08
0.04
Background Corrected Average ABS (A)
0.39
0.15
0.08
on Phys.org
You can ignore concentration of phenantroline assuming complex stability constant is so high all iron is complexed.
Are you sure because on step 8 of the PDF it says, "Calculate the molarity of
Fe(o-phenanthroline) in each solution and find the average molar absorptivity (ε in Beer's
law) from the four absorbances."
That just supports what I said - calculate concentration of complex assuming it equals concentration of iron.
ok so for the 10mL of iron I do this:
M1V1=M2V2
(10mL)(.04mg/mL)=M2(100mL)
= .004mg/mL
is that right?
and I don't have to worry about the 3.00 mL of o-phenanthroline solution, right?
Borek said:
Looks like.
Should I put the molarity in mg/L or should I convert to moles/L or can I convert to moles/L?
4 mg/L * (1mole/ 55847 mg)= 7.16 E -5 moles/L, I'm not sure if doing this is a good idea
to find the average molar absorptivity I was told to ignore the length the light travels, so it's just A/c= e
when doing the molarity should I leave it in mg/L or moles/L to calculate the molar absorptivity?
something in this experiment is sensitive to air, but I forgot which, does anyone know?
