Speed and Velocity(Driving Me Crazy)
  • Thread starter Thread starter DEdesigns57
    Speed
The discussion clarifies the distinction between speed and velocity, emphasizing that speed is a scalar quantity while velocity is a vector. A specific example involving a truck covering 37.0 m in 8.90 s illustrates how to calculate initial speed using the average velocity equation, resulting in an initial velocity of 5.7 m/s. The conversation highlights that average speed can be calculated as distance over time, while average velocity requires consideration of displacement. The conclusion is that average speed and average velocity can yield the same numerical value when direction is not specified.
  • Understanding of scalar and vector quantities
  • Familiarity with average speed and average velocity equations
  • Basic knowledge of displacement in physics
  • Ability to interpret physics problems involving motion
  • Study the differences between scalar and vector quantities in physics
  • Learn how to apply the average velocity equation in various scenarios
  • Explore the concept of displacement versus distance in motion problems
  • Review examples of motion in one-dimensional contexts to solidify understanding
Students studying physics, educators teaching motion concepts, and anyone seeking to clarify the differences between speed and velocity in problem-solving contexts.
DEdesigns57
So time and time again my professor has reinforced that speed and velocity are not the same. One is a scalar the other a vector, ect... But time and time again I will be asked to solve homework problems that ask for the speed of an object, yet the answer is velocity and using equations for velocity. Let me give you an example:
A truck covers 37.0 m in 8.90 s while smoothly slowing down to final speed of 2.70 m/s.
(a) Find its original speed.
Answer: using the average Velocity equation 1/2(Vi + Vf) and the fact that the average VELOCITY is 37.0m/8.90s, we can solve the equation for initial VELOCITY! and get Vi = 5.7m/s.
Now this does not make sense to me, first of all, if we are looking for initial speed why do we use average velocity equation. Second, if they are the same in this case, which is what I think might be happening, how do you know? The problem does not state the direction of motion in anyway. when do you then know that average velocity is the same as average speed? I just don't understand this, and I try to be very strict on the words that I see being used in the problem. When I see speed, I think one thing(distance over time) and velocity another(displacement over time). Can anyone clear this issue up for me?
Because we need to consider the direction of velocity, the average velocity is the same as average speed when it moves in one line and doesn't change the direction.
"the average velocity equation" that you mentioned is average speed equation. If you want to compute average velocity, you need compute on the vector of velocity.
my book Physics for Scientist and Engineers call this, average velocity equation. Although I know of the more basic one, which is displacement over time, My book still calls this equation Vx,avg(average velocity)
usually speed is the velocity vector's magnitude so once you have the velocity vector you can determine its magnitude and you'll have the speed but not always:
Displacement vs distance is another physics gotcha:
avg speed = (dist travelled) / (travel time)
avg velocity = (final displacement - initial displacement ) / (travel time)
Do you see the difference?
If I ran in a mile race around a track and did it in 4 minutes my speed would be 15mph because my distance was 1 mile and I did it in 4 minutes.
My average velocity would be ZERO because I ended my race where I started so the displacement vector is ZERO.
In your original problem, you are not given a direction, therefore it is called a speed (speed is a scalar has magnitude but no direction). When you solve using the velocity equation, you need to assume direction (velocity is a vector and you need to indicate both magnitude and direction). So you can say the object was initially traveling to the right, (or east or whatever direction you choose). When you compute your ans. using the velocity equation, you need to include the assumed direction. Therefore your answer to the above problem using the velocity equation is: velocity = 5.7 m/s to the right.
The solution to the problem is asking for a speed - so you do not need to indicate direction (which is a good thing, because you do not know the original direction). Your ans. will change from 5.7 m/s to the right (which is a vector), to 5.7 m/s. (which is a scalar, and no direction should be indicated). Does that make sense?
Yes it now makes sense to me, took a while but i got it. Thank you!
  • · Replies 40 ·
  • · Replies 17 ·
