Speed around earth for constant day light
To remain in constant daylight while traveling around Earth, one must match the speed of the day-night line, which varies based on latitude. This speed is zero at the poles during summer and maximum at the equator. The approximate speed can be calculated using the formula v = π * D / 24 hours, where D represents the Earth's diameter, which changes with latitude. At the equator, the diameter is about 12,742 km, while it approaches zero at the poles. Ultimately, achieving constant daylight requires understanding Earth's rotation and adjusting speed accordingly.
aiop
what speed would you half to obtain going around the Earth to be constantly in line with sun, so it would be day time aways. and how would you go about calculating this. what kinds of equation could you use. Thanks Aiop.
Science news on Phys.org
If you wish to to constantly in line with sun, you need to travel at the same speed as the day-night line travels on the earth. You can imagine a line that separate the part of Earth been lighted and not lighted or you can observe it on google earth. This speed certainly is not a fixed value, but longitude by the latitude, and it would be zero at poles during the summer, while it would be maximum at equator. Note that at opposite pole, no matter how fast you travel, you would not see the sun.
If you imagine Earth as a perfect sphere and rotates at its vertical axis, using equation v=pi*D / 24hours will give u a approximate answer, D is a function of latitude,varies from zero at pole and 6600km? at equator?
Or you could just look it up. Google the speed at which Earth rotates. If you were at the equator just go that speed in the opposite direction.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
