sporty
- 30
may someone teach me how to calculated the maximum speed from my case scissor lift? is it when at lowest point or highest point? I need your help..i can't get the equation...i got some confuse, due to at lowest point, the motor need to turn more rpm in order to lift due to mechanical advantage..horizontal lead screw distance to vertical distance lift...Beside that, at higher point the motor only need to turn lower rpm to lift vertical..due to mecHAnical advantage..the little move of horizontal will cause vertical move a lot..But in another way round, the speed should be max in lowest load which is at highest point position..but the calculation show we need highest rpm in lowest point..Why? May you teach me the correct way in calculate the maximum speed needed in my case for choosing a motor..
Thanks..
Thanks..
