Speed faster than light speed in a medium
In summary, in relativistic many-body physics, particles can travel faster than the speed of light in a material if they have a high enough energy.
abdossamad2003
68
hello everyone
I read this text in physics book:
"Another example is the so-called Cerenkov radiation, which consists of light waves emitted by charged particles that move through a medium
with a speed greater than the phase speed of light in that medium. The blue glow of the water that often surrounds the core of a nuclear reactor is one type of Cerenkov radiation"
Is it really speed faster than light for particles?!
abdossamad2003 said:
hello everyone
The short answer to your question is that the electrons move faster than the speed of light in water, not faster than the speed of light in a vacuum. When light passes through any material it slows down so, technically an object can move faster than the light does. I will leave any other details about Cherenkov radiation to the other members here.
-Dan
Likes Orodruin and vanhees71
Re-emphasized for the more relevant part of the statement. As mentioned above, the speed of light in a medium is not the same as that in vacuum. It is described by the index of refraction, which is around 1.3 for water and 1.5 for glass. This mesns that the speed of light in water is around 3c/4 and that in glass is around 2c/3, where c is the soeed of light in vacuum. These are the speeds that a charged particle would have to surpass to produce Cherenkov radiation.
A particle traveling at 3c/4 has a kinetic energy of around 50% of its mass, ie, ca 250 keV for an electron.
Likes topsquark
Are the formulas of relativity not applicable in the material environment or are they only in vacuum?
##c## is the speed of light in a vacuum, which is the invariant (and maximum) speed. ##\frac c n## is the speed of light in a material of refractive index ##n##. That is neither invariant nor the maximum speed.
Likes topsquark
The velocity you can never exceed is ##c##, wherever you are, and that is the quantity relativity uses. Light doesn't always travel at ##c##, though, for example because it slows down in a medium. In a medium you can go faster than light, but never faster than ##c##.
The "you can't go faster than light" rule is sloppy terminology, I'm afraid. The correct version is that "you can't go faster than the speed at which light travels in a vacuum (whether you're in a vacuum or not)".
Likes mfb, topsquark and malawi_glenn
Yes, they are applicable, you just need to apply them correctly. As pointed out, they use 'c', which is the speed of light in a vacuum.
So for example, if you wanted to use the addition of velocities formula for light moving through a material, which is, in turn, moving relative to you, the basic form is (u+v)/(1+uv/c^2)
If u is the velocity of the medium, then you would used c/n for v.
Likes topsquark
It is worth pointing out that this is directly related to Fizeau’s measurements of the speed of light in a moving medium.
Likes topsquark
##c/n## is the phase velocity of the light in the medium as measured in the rest frame of this medium. As such it's a scalar quantity. There's been a lot of confusion concerning relativisitic many-body physics, because in the beginning the physicists didn't get the relativistic description in the most useful and mathematically simplest form. The key to solve these problems is to define all medium-related quantities in the (local) rest frame of the medium. A good starting point is van Kampen's paper on relativistic thermodynamics:
N. G. van Kampen, Relativistic thermodynamics of moving
systems, Phys. Rev. 173, 295 (1968),
https://doi.org/10.1103/PhysRev.173.295
Likes topsquark
Related to Speed faster than light speed in a medium
1. What is faster than light speed in a medium?
According to the theory of relativity, nothing can travel faster than the speed of light in a vacuum. However, in certain mediums such as water or glass, light can travel at slower speeds, making it possible for other particles to travel faster than light in that medium.
2. How is this possible?
This phenomenon is known as "superluminal" or "faster-than-light" travel. It occurs because light is slowed down when it enters a medium due to interactions with the atoms and molecules in that medium. This allows other particles, such as neutrinos, to travel faster than light in that medium.
3. Does this violate the laws of physics?
No, it does not. The theory of relativity only applies to the speed of light in a vacuum. In a medium, the speed of light can be slower and other particles can travel faster than that speed. This does not violate any laws of physics.
4. What are the implications of faster-than-light travel in a medium?
Faster-than-light travel in a medium has many potential implications, including the ability to send information faster than the speed of light, which could have significant impacts on communication and technology. It could also change our understanding of the universe and how particles interact with each other.
5. Is faster-than-light travel in a medium possible for humans?
At this time, there is no evidence to suggest that humans can travel faster than light in any medium. The technology and understanding of this phenomenon is still in its early stages, and it is currently not possible for humans to achieve this type of travel. However, it is an area of ongoing research and exploration in the scientific community.
  • Quantum Physics
