Speed,mass,energy and a question.
At a speed of 2*10^8 m/s, a person's mass remains unchanged, but their kinetic energy becomes significantly high. The equation E=mc² does not imply that mass converts into energy at light speed; instead, it provides the energy equivalent of mass at rest. For moving mass, the correct equation is E = mc²/√(1-v²/c²), which accounts for kinetic energy. As velocity approaches the speed of light, energy approaches infinity, but mass does not change. Understanding these principles clarifies the relationship between mass, energy, and speed in physics.
shihab-kol
Suppose instead of moving at the speed of light , someone moves at a speed of 2*10^8 m/s .Then will his mas and energy exist simultaneously ? I mean mostly energy and some mass ?
At that velocity the person's mass will remain unchanged but their kinetic energy will be immense.
The way your question is phrased leads me to wonder if you are laboring under a misconception; one I have come across before.
Are you under the impression that the equation E=mc2 means that a mass moving at the speed of light has "turned into" energy. If so, that is not the meaning of this equation. While the equation contains a speed "c", this does not imply any movement on the part of the mass. The c2 part of the equation just acts as a conversion factor. The equation gives the energy equivalent of M, or the energy you would get if the mass were converted to energy (such as in the combination of two antiparticles with a combined mass of m).
In fact, this particular equation only works when you assume that mass m is at rest with respect to you. If it is in motion at velocity v, then you use
E = \frac{mc^2}{\sqrt{1-\frac{v^2}{c^2}}}
Which, if you subtract mc^2 from it, will give you the kinetic energy of of mass m at velocity v.
As Drakkith has already pointed out, the mass of m will not change as v increases. However E will approach infinity as v approaches c.
Likes jbriggs444
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
