Speed of a wave when crossing a boundary vs. not
The speed of a wave is primarily determined by the medium through which it travels, with different rules applying to sound and light waves. When sound waves cross from a less dense medium to a more dense one, their speed can increase if the denser medium is also stiffer, as seen in materials like steel. The relationship between wave speed, density, and stiffness is complex; while density affects speed, stiffness plays a crucial role as well. Additionally, for gases, temperature significantly influences the speed of sound. Overall, each wave and medium must be evaluated individually to understand their specific behaviors.
Skrphys
I am having a problem with understanding concepts related to the speed of a wave. Here are my thoughts laid out:
1) The speed of a wave is dependent only on the medium
2) When a wave crosses from a less dense medium into a more dense medium (or visa versa) the speed of the wave is always fastest in the less dense medium.
3) When a wave (particularly a sound wave) is introduced into a medium, the more dense the medium, the faster the wave travels.
These statements seem to be conflicting. Can anyone rectify the situation for me?
Thanks in advance!
Thanks in advance!
These are two different waves that have different mechanisms.
Light waves actually travel in vacuum. So a "medium" can be naively thought of as "obstacles" in its path.
Sound waves are the oscillation of the medium. So it is the material that make up the medium that oscillates to cause such a wave. Thus, the more dense, the quicker the disturbance is transferred to the neighboring regions.
Zz.
For number 2, you might be imagining a sound wave in helium versus a sound wave in air. Indeed, sound travels more rapidly in helium. And helium is less dense than air. For number 3, you might be imagining a sound wave in steel versus a sound wave in air. Indeed, sound travels more rapidly in steel. And steel is more dense than air.
The speed of a compression wave depends not only on density, but also on stiffness. Sound travels rapidly in steel because steel is very stiff, not because it is very dense. See Wiki.
Likes sophiecentaur
Read about "dispersion" of waves in a medium, and maybe update this line? :smile:
Likes sophiecentaur
Too much of a simplification. In a solid
v = √(K/ρ)
where K is the Stiffness. So , although inversely affected by density, the stiffness counts just as much)
In a gas, the speed of sound is largely dependent on the Temperature. That's because the speed of propagation from molecule to molecule will depend on their individual average speeds.
Bottom line is that there are no general rules and each wave and material needs to be taken on its own.
Likes berkeman
Thank you all for your posts. Sometimes I forget that often times in physics approximations are used.
Likes berkeman
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
