davenn said:
thanks for that
it sort of goes against all I have learned that says increasing density ( of any material) increases speed of propagation. Didnt realize that a gas doesn't fall into that category
cheers
Dave
Interestingly enough, in the absence of any other changes, an increase in density actually decreases the speed of propagation. There are a number of (provably equivalent) statements for the speed of sound, depending on which parameters you want. As stated above, for an ideal gas, it is equal to √(γRT). However, it is also (in general) equal to √(E/ρ), in which E is the bulk modulus (how difficult the substance is to compress), and ρ is the density. As you can see, as density increases, the speed of sound actually decreases. The reason why the speed of sound is higher in some dense media (such as metal or water) than in some low density media (like air) is because the bulk modulus of water or of steel is much, much higher than the bulk modulus of air, and this increased bulk modulus more than makes up for the increased density. Alternatively, it is also equal to √(dP/dρ) (that should be a partial derivative by the way, but I can't figure out the proper formatting).
One way that may help visualize this is to think of the medium in which sound is propagating as a string of masses connected by springs (so you have a mass, then a spring, then another mass, then another spring, etc). The bulk modulus of the material is like the strength of the springs, while the density is like the mass of each individual weight in the string. If you push on the end of it, introducing a compression wave, it is very much analogous to a sound wave propagating through a material.
Now, replace those springs (in your mind - or in the actual system - this wouldn't be that hard to build as a demonstration unit...) with weaker ones. This is like decreasing the bulk modulus of the material, making it more compressible. It's fairly intuitive that the wave will propagate slower.
Next, change the weights. Once again, it's fairly intuitive that heavier weights (representing a material with a higher density) will cause the wave to propagate slower, not faster. When visualized this way, it becomes a lot more clear that density has the opposite effect of what is commonly thought.
Unfortunately, in terms of sound speeds in real, physical materials, it's impossible to perfectly separate out bulk modulus and density like this, and this is where the confusion often arises. Air, being a gas, has an incredibly low bulk modulus, and thus a very low sound speed. Water, being a liquid, has a very high bulk modulus, and thus a higher sound speed, despite having a density approximately a factor of a thousand higher. Many people see this fact, and they immediately jump to the conclusion that density is the reason, rather than the compressibility of the material, leading to the widespread nature of the misconception.
