Speed of light - causality - etc
Traveling faster than the speed of light can lead to significant implications for causality, as it may allow for events to be perceived in a non-linear sequence. This phenomenon, known as "closed timelike loops," suggests that information could be received before it is sent, challenging traditional notions of cause and effect. Unlike sound, which does not exceed the speed of light, exceeding light speed could warp space and time, resulting in events appearing simultaneous or even reversed in order from different reference frames. The concept of relative simultaneity indicates that what is simultaneous in one frame may not be in another, complicating our understanding of causation. Ultimately, the discussion highlights the intricate relationship between speed, time, and causality as outlined in the theory of Special Relativity.
DwithQs
I've seen other posts about this, but would appreciate an explanation if anyone knows.
I've read that traveling faster than the speed of light could affect causality. Example: item I traveling in a tube could be seen arriving at end B before it ever left end A.
A=======I=B
Is this an actual affect on causality or just the light reaching the observer? I am trying to compare it with speed of sound. Travelling faster than the speed of sound may affect when an observer hears something, but not actually when the sound is made.
Science news on Phys.org
It is one of the axioms underlying the theory of Special Relativity that the laws physics are the same no matter what inertial frame of reference you use to describe them.
So if the laws of physics allow you to send an object faster than light from the point of view of one reference frame, all you have to do is speed up your sending apparatus and you can send an object faster than the speed of light from the point of view of any other reference frame.
It is a simple consequence of Special Relativity (more specifically a property of the Lorentz transform) that an object that is moving faster than the speed of light in one frame of reference is moving backward in time as viewed from another.
Put this together just right...
Start from your choice of frame of reference. Say one in which the Earth is more or less at rest. Put a message in a cannister and launch it faster-than-light. But launch it from an apparatus that is moving fast enough that the resulting motion is backwards in time from the point of view of the Earth frame. At the far end, arrange for a receiver to catch this message, put it in another canister and launch it back. Again, launch it from an apparatus that is moving fast enough that the resulting motion is also backwards in time from the point of view of the Earth frame. Back on Earth, receive the canister, unwrap the message and read it -- before you wrote it.
That's not just a matter of light reaching the observer. That's actionable information. Fodder for all sorts of causality paradoxes if you can A) build such an apparatus, B) send information using it and C) act on it arbitrarily.
This sort of thing is sometimes referred to as a "closed timelike loop".
Its an actual affect on causality, even after the travel time of the light reaching the observer is corrected for. Its different from the way sound works because the speed of sound is not the absolute speed limit of space. What you are asking about is called Relative Simultaneity of Events. It is pretty hard to understand, visual aids help.
Energy warps space. Kinetic energy warps space in the direction of motion by compressing it in that direction. If you travel towards a distant object at relativistic speed, the amount of space between you and that object appears smaller to you, it takes less time for light to travel from that object to you, so it seems like you just jumped into that object's past (compared to a prior measurement made a rest with respect to the object) since the light (and any other form of information) you are receiving from that object is essentially the same, and you calculate that it took a shorter time to travel to you from that object through the compressed space.
Moving towards (or away from) a pair of distant objects where one is farther from you than the other compresses the distance between the two objects from your point of view. It takes less time (in your reference frame) for light to move from one to the other the faster you move toward them. If an event at the more distant object causes and event at the closer object then the causal event must precede the caused event in all inertial frames of reference. But as you travel towards them they seem to happen closer together in time, this is ok since you still see the information traveling from one to the other at less than or equal to the speed of light, its just that the space is getting smaller and smaller. However, if you are going at the speed of light exactly, the space between them becomes infinitely small, and the events happen simultaneously in your reference frame. If you were able to go even faster than that, the events would swap causal relationships, you would see time run backwards, distances would be negative... all sorts of bad things would happen. You would collapse into a black hole, I don't recommend it.
This is called relative simultaneity because events that are simultaneous in the rest reference frame are not simultaneous to an observer moving with respect to that reference frame. Simultaneous distant events are by definition not causal and can be seen to occur in different order depending on which one is farther away from you.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
16K
