Speed of light in and out of vacuum
The discussion revolves around the behavior of photons as they travel through different media, particularly in a vacuum versus a medium like glass. When photons are emitted simultaneously from two sources, they arrive at their respective receptors at the same time in a vacuum, but the introduction of a medium delays one photon, raising questions about whether the photons remain the same after passing through the medium. It is argued that due to quantum statistics, particularly the concept of indistinguishability, tracking individual photons becomes impossible, making it irrelevant to determine if the same photon that left the emitter is the one that arrives at the receptor. The analogy of photons behaving like quasiparticles in a medium is introduced, emphasizing that their identity is lost in such contexts. Ultimately, the discussion suggests that unless new physics emerges that relies on this distinction, the identity of the photon is not a significant concern.
Jobrag
I've read ZapperZ's thread on the speed of photons through a solid and am still confused.
If you imagine an experiment where two emitters A and B are set up to emit one photon each simultaneously towards two receptors (also A and B)in a vacuum 558,000 miles away. The receptors will sense the arrival of the photons approximately 3 seconds after they leave the emitters and should “see” them simultaneously.
Are the photons that arrive at the receptors the same photons that left the emitters?
If you now put a piece of glass 186,000 miles thick between the B emitter and B receptor and repeat the experiment the B receptor will “see” the photon slightly later then the A receptor.
If the answer to my first question was yes, is the photon that hits the B receptor in the second test the same photon that left the B emitter?
Science news on Phys.org
Does it matter? Is there something in the original photon that you can encode to identify it from other photons?
There is a section on quantum statistics called "indistinguishibility" which is applicable to bosons and fermions. In this case, you can no longer track particle by particle the way one can do with classical statistics, even if they all look the same (4 red balls). When you get into such a quantum statistics, it no longer makes sense to describe the system in such a way that you can track each individual particle.
So asking if it is the "same" photon, after it passes through a medium, can't be answered, because there is no way for me to check if it is, or if it isn't. Note that this is applicable also to reflection. Is that the same photon that bounced off the surface of a mirror? Or what about the supercurrent in a superconductor. Are those the same electrons that originally formed the bound pairs on one side of the superconductor?
When it makes absolutely no difference if it is the same ones or not, we tend to try not to worry too much about such things. If you can find some new physics that does depend on whether it does, then that's a different story.
Zz.
In a medium, the photon's « identity as a particle »* is lost. It behaves as a quasiparticle like a phonon. I like this analogy with the phonon. When you have a whole crystal vibrating, the question “where is the phonon?” doesn't make much sense. That's the same for a photon in a medium :smile:
Now, think of the vacuum as any other medium (after all, vacuum has a refraction index, a permittivity, a permeability, etc…)
* I don't like those words… Take this analogy with caution
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
12K
