Speed of moving shadow due to light source
The discussion focuses on a calculus problem involving the speed of a shadow cast by a girl running under a street light. The girl, 5 feet tall, runs at 12 feet per second beneath a 20-foot street light. The correct interpretation of the problem reveals that the length of her shadow increases at a rate of 4 feet per second, while the speed of the tip of the shadow is 16 feet per second. The distinction between the rate of change of the shadow's length and the speed of the shadow's tip is crucial for solving the problem accurately.
  • Understanding of related rates in calculus
  • Knowledge of similar triangles
  • Familiarity with basic algebraic manipulation
  • Concept of instantaneous rates of change
  • Study related rates problems in calculus
  • Explore the concept of similar triangles in geometry
  • Practice algebraic manipulation techniques for solving equations
  • Learn about instantaneous rates of change and their applications
Students studying calculus, educators teaching related rates, and anyone interested in applying geometric concepts to real-world problems.
hqjb
A girl 5 feet tall is running at the rate of 12 feet/second and
passes under a street light 20 feet above the ground. Find how
rapidly the length of her shadow is increasing when she is 20
feet past the base of the street light.
I let the distance of girl from light be S = 12t
I let the distance of shadow from light be X,
Due to similar triangle,
\frac{x}{x-12t} = \frac{20}{5}
-15x=-240t
x=16t
\frac{dx}{dt}=16
But the ans is 4ft/sec any clues as to where I went wrong?
The problem does not want dx/dt. Because x is not the length of her shadow. x is the length of her shadow plus her distance from the base of the street light.
Ah...semantics. Thanks. So I suppose that if they were looking for the speed for the tip of the shadow then that would be the right answer?
Yes. Your answer of 16 ft/second is the speed of the tip of the shadow. The rate of change of the length of the shadow is different to this because the other end of the shadow (at the girl) is also moving.
  • · Replies 57 ·
12K
