Speed of pendulum at certain angles
  • Context: Undergrad
  • Thread starter Thread starter Bronzer
    Angles Pendulum Speed
The discussion focuses on calculating the speed of a pendulum at a specific angle of 30 degrees after being dropped from 140 degrees. The approach involves using the change in gravitational potential energy (PE = mgL(1 - cos θ)) to determine the corresponding kinetic energy (KE = 1/2 mv²). The calculated speed at 30 degrees is approximately 3.38 m/s, assuming a pendulum length (L) of 1 meter. The importance of including the length of the pendulum in calculations is emphasized, as it directly affects the speed.
  • Understanding of gravitational potential energy and kinetic energy concepts
  • Familiarity with basic trigonometry and the cosine function
  • Knowledge of pendulum mechanics and motion
  • Ability to perform algebraic manipulations and solve equations
  • Research the effects of pendulum length on speed and motion
  • Explore advanced pendulum dynamics, including damping and driving forces
  • Learn about energy conservation principles in mechanical systems
  • Investigate the differences between ideal and real pendulum systems
Physics students, educators, and anyone interested in understanding pendulum mechanics and energy transfer in oscillatory systems.
Bronzer
I'm having no problem finding the maximum speed of a pendulum but I'm not sure when I move its start point and measure point.
I would like to know the speed of a pendulum at 30 degrees that has been dropped at 140 Degrees. I'm just giving some numbers to explain that it is above the horizontal and doesn't pass through equilibrium.
Any thought's on this would be useful.
Thanks.
You need to give more background. Where are you in school? What math have you taken?
Out of school, AS level Math.
This isn't homework, just a practical problem I'm trying to get my head around.
All of my usual point of calls don't like pendulums that go above the horizontal (I guess GCSE assumes it's made of string) and I can only find equations for Vmax.
As with many such problems, you can either approach this problem by considering the Forces involved or by considering the Energy transfer. The Maths is pretty straightforward if you work out the change in gravitational potential energy and the corresponding gain in Kinetic Energy. That is an enormous clue!
That assumes the pendulum uses a solid rod (like most practical pendulums, aamof) If you want to assume string then you would have to know an awful lot more about the set up - the shape of the bob, for instance.
Right, so if I take energy of pendulum equation as
PE = mgL(1 – COS θ)
Mass should be irrelevant for this(?)
9.81*1*(1-cos(140))=13.2
9.81*1*(1-cos(30))=7.5
= 5.7j change
KE=1/2mv^2
2KE=mv^2
sqrt(2KE)=mv
Ignore M, so that V = sqrt(2*5.7)
=3.38m/s
Is that looking ok?
You lost L somewhere? But that's the sort of thing I meant.
Yeah L=1, sorry.
By choosing a magic number for L you have thrown away an important part of the relationship. The speed cannot be independent of L, can it, so you should include the length even if you later happen to give it a value of 1m, 1cm, 1km.
13K
  • · Replies 19 ·
  • · Replies 16 ·
