Speed of the second hand of a smoothly running analog watch?
The discussion focuses on calculating the angular speed of the second hand of a smoothly running analog watch. The correct angular speed is determined to be 6 radians per second, derived from the formula w = theta/t, where theta is 360 degrees and t is 60 seconds. Participants emphasize the importance of converting degrees to radians correctly, noting that 360 degrees equals 2π radians. There is confusion regarding the syntax required by webassign, particularly with the inclusion of π in answers. Ultimately, the correct approach involves converting the speed to radians without using π in the final answer.
akoma714
(a) What is the angular speed of the second hand of a smoothly running analog watch?
____ (rad/s)
i got 0.03 pi
webassign says "Check the syntax of your response"
i also tried 0.03, but it's wrong also..
how do i put my answer?
In radians. pi=180 radians, so 0.03pi= 0.03*180=5.4 radians.
But, w=theta/t=360/60=6 radians/second.
hmm, those were all wrong.. i don't know
I believe that gives you 6 degrees per second, which still needs to be converted into radians. There are 2 \pi radians in a whole circle.
From the fact that when you entered "pi" webassign told you to check your syntax, I assume that this problem will not accept pi as part of an answer--if you get an answer with pi, multiply out!
360deg/1min = 360deg/60sec = 6deg/sec x 1rad/180deg = 0.03 rad/sec?
OH! I get it now..
360deg/60sec x 2pi rad/360deg = 0.105
Thanks for the help =]
akoma714 said:
360deg/1min = 360deg/60sec = 6deg/sec x 1pi rad/180deg = 0.03 pi rad/sec?
=(0.0333)*(3.14159...)=_________
edit: you beat me :). Happy physics!
BTW, notice that you multiplied and divided by 360o. You could have just started working in radians and saved yourself the trouble (but it would have required thinking in new units to begin with).
