Spherical co-ordinates conversion
  • Topic:
  • Thread starter Fermat1
    Spherical
11 replies · 3K views · last reply
Fermat1
Consider the region above the $z=-\sqrt{2-x^2-y^2}$ and below $z=-\sqrt{x^2+y^2}$.
Let $x=r\sin\phi\cos\theta$, $y=r\sin\phi\sin\theta$, $z=r\cos\phi$
I want the range of the variables. I get $0\leq r\leq\sqrt{2}$.
How do I work out the range of $\phi$ and $\theta$ ?
Simplest is by drawing those surfaces.
The first is a demi-sphere below the $z=0$ plane.
The second is a cone, also below the $z=0$ plane.
In polar coordinates you will have the full range for the longutide $0 \le \theta < 2\pi$.
Edited:
And the colatitude begins at the cone.
That is, $\frac{3\pi}{4} \le \phi \le \pi$.
And the colatitude begins at the $z=0$ plane and ends at the cone.
That is, $\frac \pi 2 \le \phi \le \frac{3\pi}{4}$.
Hi can you explain how you found those angles-how do they relate to the equations for z?Thanks
Let's take a look at the cone $z=-\sqrt{x^2+y^2}$.
Substituting the definitions of the polar coordinates, we get:
$$r\cos\phi = -\sqrt{(r\sin\phi\cos\theta)^2 + (r\sin\phi\sin\theta)^2} = -r\sin\phi$$
Since $\theta$ is not present in this equation, we need its full range.
Solving it for $\phi$ in the domain $[0,\pi]$ gives $\phi=\frac{3\pi}{4}$.
So to integrate above the cone, we need $0 \le \theta < 2\pi$ and $\phi \le \frac{3\pi}{4}$.
thanks, do you mean integrate below the cone?
Ah. To integrate below the cone it should be $\phi \ge \frac{3\pi}{4}$.
How do you get the upper limit? When I use the other equation I 'lose' ${\phi}$. Does that signify there is no upper restriction (apart from ${\pi}$)?
Yes.
I like Serena said:
Yes.
How about this. Calculate the outward flux through the surface $x^2+y^2+z^2=1$ of a fluid with velocity field $F$.
When I convert to spherical, the range of both anges should be [0,${\pi}$/2] Why is there this restriction?
Thanks
Thanks
There is no implicit reason for such a restriction.
The text must have explicitly stated any restrictions.
