What is the effect of arranging two springs in series?
Arranging two springs in series results in an equivalent spring constant that is lower than the stiffness of the weaker spring, as demonstrated by the formula 1/k = 1/k1 + 1/k2. In this case, with K1 at 5 and K2 at 100, the calculated equivalent spring constant is approximately 4.76. This occurs because the force acting on the system is primarily influenced by the weaker spring, leading to increased overall compliance. The discussion also raises the question of how initial lengths of the springs could affect the overall stiffness, suggesting that visualizing the springs under force could clarify this. Ultimately, adding a stiffer spring in series does not increase the overall stiffness beyond that of the weaker spring.
chrom68
I have two springs arranged in series (remember circuit diagrams from physics class!).
One has a low stiffness constant (K1 = 5) and the other connected to it has a much higher contant (K2 = 100). According to the equation (as used in wikipedia):
<br /> \frac{1}{k}=\frac{1}{k_1}+\frac{1}{k_2}<br />
http://en.wikipedia.org/wiki/Hooke%27s_law"
Question 1)
Using this i get my equivalent spring constant to be K = 4.76, which is less than K1?
I don't understand why. I would expect the equivalent constant to be much higher (but less than K2=100).
Question2)
This formula doesn't consider the initial lengths of each spring. How could it do so?
Question 1)
Question2)
Probably best to draw the springs in their initial state, and then compressed under some force. You should be able to derive the equation based on that.
The overall K will be lower than the weaker K, because your force "sees" the weaker K, plus some additional compression beyond what just the weaker K offers. Thus, the overall K appears a bit weaker than the weaker K. Make sense?
Imagine you have a very soft spring and a very hard spring in series.
You haven't done anything to make the soft spring any harder so the overall stiffness can't be any more than the soft spring (imagine attaching the soft spring to an infinite stiffness rod).
But you have added a strong spring which will give a little (however small) and so the overall system must have a little more give = overall stiffness must be less
I understand that the soft spring doesn't become any harder therefore shouldn't the overall stiffness still be greater than K1 (by just a small amount)? Surely adding a stiffer spring in series wouldn't make the stiffness weaker overall.
Draw the drawings I suggested in my post, and work through the numbers with some examples. What do you find?
Quiz Question -- what do you get for the composite K when you put two springs with identical K values in series? Why?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
