Spring Force and Acceleration with Friction
The discussion focuses on calculating the acceleration of two blocks released from rest, separated by a compressed spring with a force constant of 3.85 N/m. Initially, the user incorrectly used the compression distance in their calculations, but later corrected it to 0.08 m for both blocks. For cases with friction, the user learned to apply Newton's second law, incorporating the frictional force, which led to determining that higher friction coefficients could prevent the blocks from moving. The final calculations indicated that under certain friction conditions, the blocks may not accelerate at all. The conversation emphasizes the importance of correctly applying physics principles to solve the problem.
Adrianw2
A light spring with force constant 3.85 N/m is compressed by 8.00 cm as it is held between a 0.250-kg block on the left and a 0.500-kg block on the right, both resting on a horizontal surface. The spring exerts a force on each block, tending to push them apart. The blocks are simultaneously released from rest. Find the acceleration with which each block starts to move, given that the coefficient of kinetic friction between each block and the surface is (a) 0, (b) 0.100, and (c) 0.462
Fx = -kx
F = ma
W = the integral of Fxdx from initial to final position
W = FΔR
Ffriction = umg
Here's my attempt so far, but I don't think it's right.
Since Fx = -kx and F = ma then ma=-kx and -kx/m = a
So for the first block (-3.85N/m)(0.04m)/(0.250kg) = 1.232 m/s2
And for the second block (-3/85N/m)(0.04m)/(0.500kg) = 0.616 m/s2
I chose 0.04 m, because that is the amount the spring is being compressed on each side, maybe I am supposed to use 0.08 m in the equation anyways though.
For the cases with friction I believe I would have to subtract the force of friction in the F = ma and somehow put it in the equations I used in part b and c.
Anyway, I don't even know if I started the question correctly, but any help would be awesome.
Thanks
Fx = -kx
F = ma
W = FΔR
Ffriction = umg
Thanks
Good start, but you used the wrong delta x, and you've got to watch your direction of the acceleration for each block. The spring is compressed 8 cm, and that is the distance you must use in calculating the spring force, which is the same on each block. For part b, yes, use Newton 2 after identifying the value and direction of the spring and friction forces.
So this would be the correct answer for the first part then?
So for the first block (-3.85N/m)(0.08m)/(0.250kg) = -1.232 m/s2
And for the second block (-3.85N/m)(-0.08m)/(0.500kg) = 0.616 m/s2
I had actually calculated both of the accelerations with the 0.08m last time, but I included the proper directions this time.
And for part b would it look something like this?
Fx = -kx and F = ma +/- umg then ma = -kx +/- umg and a = [(-kx)/m] +/- ug
The reason I have +/- umg is because friction is acting in a different direction in both cases
So for the first block [-1.232m/s2] + [(0.100)(9.81m/s2)] = -0.251m/s2
And for the second block [0.616m/s2] - [(0.100)(9.81 m/s2) = -0.365m/s2
I don't think I have the part b right now that I look at it, if somebody could tell me where I went wrong that would help a lot.
Thanks again
I think that for part b and c if you just see for the magnitudes then the following would be right.
kx - \mu}mg = ma
Part a looks good. In part b, the acceleration is not the same as in part a, so don't use it. For the left block, you've fot the spring force acting left and the friction force acting right. Use Newton's law. Careful using the different friction coefficients that are given. In some cases, Newton 1 may apply.
kx - \mu}mg = ma
When I do that I get the same numbers as above and that doesn't make sense, especially with friction because the larger block has a higher acceleration, could you possibly try out your way with the numbers so I can see if I actually understand what you're saying?
So it will be net force divided by the mass to get acceleration
First block: -(kx - umg)/m = a = [(-3.85N/m)(0.08m)+(0.100)(0.250kg)(9.81m/s2)]/0.250kg = -.0251m/s2
Second block [(-3.85N/m)(0.08m)-(0.100(0.250kg)(9.81m/s2)]/0.500kg = a negative number indicating that the friction force is too high and the block won't move?
Just apply
kx - \mu}mg = ma
And that would be the answers.:smile:
FedEx said:
Just apply
kx - \mu}mg = ma
When I do that I obtain the same answers I got in the post above, so I assume they were right. And for part c I get answers that suggest both blocks aren't moved when the coefficient of friction is that strong.
So for part c are you getting zero for a.
Well, I'm getting answers where the force of friction is greater than kx meaning the blocks won't be able to go anywhere.
Thanks a bunch for all the help, I think I've got it all now.
  • · Replies 37 ·
  • · Replies 19 ·
