Spring, Mass , Dumper system. Dumper Value.
2 replies · 3K views
Bluesky1
Spring, Mass , Damper system. Damper Value.
Hi,
I have a problem with first question from site below:
http://engineeronadisk.com/V2/notes_courses/engineeronadisk-91.html#pgfId-521824
I was trying to solve it using transmissibility equation but there is no mass so I can't find a natural frequency.
Transmissibility is in this case 0.01% because the isolation required is 99.9%.
T= sqrt {[1+4*d^2*(f/f0)^2]/[(1-(f/f0)^2)^2 + 4*d^2*(f/f0)^2]}
d- damper value
f- frequency which is 100Hz
f0- natural frequency
The other way is to use dynamic equation and then find transfer function:
dynamic equation: cx' + kx = M x''
but the Mass is unknown and it's the problem.
Please help
I believe you are correct - you need the mass, and there is no way to absorb it into the value of the damping coefficient. I guess you could proceed by assuming some convenient value for the mass.
Thanks for answer,
The other way that i was trying to assume that system is in resonance because of low damper value, but 100Hz of forcing frequency doesn't need to be natural frequency.:(
First question when I have started to practice and I found without enough data.
Ehhh I'm lucky :cool:
