Spring powered dart gun conceptual question
In a discussion about a spring-powered dart gun, participants analyze the time it takes for two darts—one regular and one with double the mass—to hit the ground after being fired straight down. The consensus is that both darts take the same time to reach the ground due to the principle of conservation of energy, as mass does not affect free fall. However, when considering the acceleration imparted by the spring, the heavier dart experiences lower acceleration, leading to the conclusion that the regular dart will reach the ground first. The conversation emphasizes the importance of understanding the dynamics of motion and energy in this context. Ultimately, the regular dart is determined to take less time to hit the ground.
freshcoast
1. Problem statement.
A spring powered dart gun fires darts straight downward towards the Earth from the same height each time. First it fired a regular dart, then a dart with twice the mass. Which dart takes the least time to reach the ground after exiting the gun?
A) the regular dart
B) the weighted dart
C) each takes the same time
D) there is insufficient information to answer the question.
2. Related equations
3. Attempt at solution
Just to make sure I got the correct answer, would both darts take the same time to reach the floor since the energy is conserved and the mass has no effect on the velocities?
The mass has no effect in the free fall. What about the motion in the gun, when masses are accelerated by the spring?
Oh I see, if I use the equation work done by spring = force x d, convert the f into ma, solve for a, the heavier mass would have a lower acceleration since the energy from the spring is being divided by the heavier mass?
Your conclusion is correct. So what's the answer to the original question?
So the regular dart will take less time to reach the ground
Good!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
