Spring (with mass) kinetic energy -- velocity assumption
The discussion centers on the assumption that the velocity of a particle in a spring decreases linearly when one end is fixed, with the velocity at a distance x from the fixed end expressed as vx/l. This assumption holds true even for non-uniform springs, as long as all parts of the spring compress uniformly. The relationship between distance and speed can be derived using the spring constant and considering forces acting on different elements of the spring. The analysis shows that the velocity of an element can be expressed in terms of the velocity of the free end, maintaining the validity of the linear relationship. Overall, the principles discussed clarify how velocity distribution in a spring remains consistent despite variations in mass density.
ELiT.Maxwell
why we assume that velocity decreases linearly in a spring (i.e. if one end is fixed, then velocity of a particle (of spring) at x from fixed =vx/l where v is the velocity of the free end) and why does it hold good too when the spring (linear mass density) is non uniform...
EDIT: spring has mass..
ref : https://en.wikipedia.org/wiki/Effective_mass_(spring–mass_system)
If every part of the spring compresses in the same way, that's the result.
Not all springs are uniform - if they are not, you might need a different relation between distance and speed.
Likes ELiT.Maxwell and vanhees71
by using spring constant inversely proportional to length and letting a element y from fixed end and Fnet=0 on it so,
K(L/y)x1=K(L/(L-y))x2
where L is the length of spring at any time t, now, y/x1=(L-y)/x2
x1+x2=x these are lim->0 inst changes and x1 = velocity of element and solving eqn , v=y/l(v of free end)
and, since we have not touched linear mass density (only used absolute lengths...) it works
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
