You might want to crop your image (it's taking up a lot of space.)
thercias said:
A square loop of wire is made up of 50 turns of wire, 45 cm on each side. The loop is
immersed in a 1.4T magnetic field perpendicular to the plane of the loop. The loop of
wire has little resistance but it is connected to two resistors in parallel as shown.
(a) When the loop of wire is rotated by 180°, how much charge flows through the circuit?
(b) How much charge goes through the 5.0Ω resistor?
F = I(LxB)
B= uNI/L
V = IR
flux = BAcostheta
Is this for a calculus based physics class? I'm guessing it's for a calculus based class.
I'm stuck at this question and don't have a clue how to start.
For this problem, there are actually several different places to start. This problem combines several different aspects of electricity and magnetism (such induced
emf, equivalent resistance, charge vs. current relationship). And realistically, you could start on anyone and come back to it later, combining things.
The good news is that if you understand this problem, you'll get a pretty good understanding of a large part of the whole subject.
So I'm not going to give much away. I'd like you to think about things as you go.
I think I have to somehow find the current flowing through the resistors,
In a manner of speaking, yes. You won't necessarily need to find the current directly, but a current variable might show up in one or two of the forthcoming equations.
and somehow use that to find the charge.
Yes. You will need to find the charge.
Can someone show me the steps to complete this problem?
My partial attempt:
flux = BA
= 1.4*0.45^2
=0.2835
Don't forget your units. But anyway, yes, that's the flux when the loop is at an angle
θ = 0
o.
But let's not throw in numbers just yet (that's best done at the end).
What's the flux as the angle
θ changes? Can you express the flux as a function of
A, B and
θ? You'll end up needing that.
In general that equation isn't true. That's the
emf for the special case where the flux is changing linearly, at a constant rate [Edit: and only if the flux is 0 at
t = 0]. But that's not necessarily the case for this problem. (Also, you forgot a negative sign.)
Can you express the
emf in more general terms? [Use calculus based notation such as "d()" and "dt".]
