SR's Length Contraction and Time Dilation
epkid08
If an observer rotates a four dimensional object, the lengths of the object would change to the observer. If that same observer walks backwards, the lengths of the object will also appear to change from his frame. In fact, if either the observer or the object rotates or moves in any way, it will also appear to the observer that the object's lengths have changed. This is very similar to the effects of special relativity in our world.
Here's the question, is length contraction, time dilation, etc, actually just consequences of a fourth spatial dimension?
I don't follow your logic, but we can only detect 3 spatial dimensions in any case. If there are others they must be microscopic and/or cyclic or we would could move around in them.
However Euclidean relativity introduces a fifth dimension, and all four dimensional things in the 5-space move at c, while all us 3d beings suffer the laws of SR.
See here www.physicsforums.com/showthread.php?t=103977 for a discussion and some links.
Yes, we can only detect three dimensions, the fourth is brought to us through contortions of our detected three, i.e. length contraction.
I wish you would read beyond the first two sentences I wrote. They are merely cautionary because there is no evidence for extra dimensions.
Euclidean relativity theory, does exactly what you want, boosts become rotations into an extra spatial dimension, thus creating length contraction in the normal 3-space slice.
So the answer to your question is - yes it is possible to make a theory where this happens.
The fourth dimension isn't space, it's time.
A change of speed is the 4D-equivalent of a rotation in 4D spacetime. Length contraction and time dilation can be viewed as consequences of the rotation.
A rotation in 2D Euclidean space through angle \theta can be written as
x' = x \cos \theta - y \sin \theta = \Gamma (x \, - \, V \, y)
y' = y \cos \theta + x \sin \theta = \Gamma (y \, + \, V \, x)​
where \Gamma = \cos \theta and V = \tan \theta. Compare this with the Lorentz transform
x' = \gamma ( x \, - \, (v/c) \, ct )
ct' = \gamma ( ct \, - \, (v/c) \, x )​
(I wouldn't get involved in "Euclidean relativity", as that is a somewhat contentious, non-mainstream topic.)
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
