Standards of Length, Mass, and Time
  • Thread starter Thread starter knightassassin
    Length Mass Time
To find the radius of the second sphere, the relationship between mass, volume, and density is crucial, given that both spheres are made of the same uniform rock. The volume of a sphere is calculated using the formula (4/3)πr^3. By setting the mass-to-volume ratio equal for both spheres, the equation m1/v1 = m2/v2 can be used. Substituting the volume formula into this equation allows for solving the radius of the second sphere, which is found to be 5.4 cm. This approach effectively demonstrates the application of geometric and physical principles to solve the problem.
knightassassin
Two spheres are cut from a certain uniform rock. One has radius 4.30 cm. The mass of the other is two times greater. Find its radius.
Not sure what equations to use for it
I am not sure how to attempt this problem?
Mass is volume times density. 'Uniform' rock means you can assume the two rocks have the same uniform density. Now do you know a relation between the radius of a sphere and the volume?
Volume equals (4/3)pi radius^3
Good then you are all set to go. Try solving it.
Thanks I got it. So I set the two relations equal to each other m1/v1=m2/v2. Substitute volume for their equation of (4/3)pi radius^3 and solve for r2.
The answer I got was 5.4 cm, which is right thanks again.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
