Standing waves and banjo string
5 replies · 3K views
phyzeek
1. A banjo string 36.0 cm long oscillates in a standing wave pattern. It resonates in its
fundamental mode at a frequency of 250 Hz. What is the tension in the string if 80.0 cm of the
string has a mass of 0.75 grams?
k=2pi/lamda
velocity=sqrt(F_tension/miu)
miu=m/l
w=2pif
v=sqrt(F_t/miu)
solved for miu and plugged into equation: 7.5*10^-4/.8
v=lamdaf
L=lamda/2
--> v=2Lf
v=2(.8)(250)
then equated both equations
i think i got confused with which length to use
I think your work is ok.
Yes - mu =m/L and for fundamental frequency lambda = 2L.
I'm not sure when to use the length of the banjo string (36cm) :[
When the string is vibrating in its first overtone, i.e. its second harmonic, then the length of string will be the wavelength.
thank u. my answer is still incorrect... i would appreciate any more help. thank you
May I correct my own contribution above.
mu = m/L where L = 0.80m but lambda = 2 x 0.36 since this is the length which is oscillating.
