State transition matrix to change initial conditions.
The discussion focuses on using a state transition matrix to adjust initial conditions in a circular restricted three-body problem. The user is attempting to achieve zero velocities for x'(t/2) and z'(t/2) at the halfway point of the orbit but is struggling to do so despite following a referenced paper. Although they can reduce one velocity to zero, the other increases, making it impossible to achieve both targets simultaneously. The user has confirmed the accuracy of their state transition matrix but has not seen progress after two weeks of attempts. Additional information about numerical values and conditions is available upon request for further assistance.
Deadstar
Hey folks, I have an orbit in the circular restricted three body problem with initial conditions
[x(0), 0, z(0), 0, y'(0), 0]
I'm following this paper
http://adsabs.harvard.edu/full/1984CeMec..32...53H
on how to correct these initial conditions given the state transition matrix at a certain time (in this case, the halfway point of the orbit which I'll call t/2).
The orbit is integrated until it crosses the y-axis again and at that point the position and velocities are given by
[x(t/2), 0, z(t/2), x'(t/2), y'(t/2), z'(t/2)].
I want to use the state transition matrix to drive x'(t/2) and z'(t/2) to zero by changing the initial condition but I can't get this to work. I have the state transition matrix at t/2 but following the methods in the above paper does not send them to zero. They both decrease for a couple of iterations but then one start to increase.
I can send either x'(t/2), or z'(t/2) to zero (by a little trial and error) but as you decrease one the other increases, it just seems impossible to send them both to zero. I'm following the exact method described in the above paper and it should only take 3-4 iterations apparently. My state transition matrix is correct as it been confirmed by a separate code I found online.
So, I have...
State transition matrix at t/2
Initial conditions
position and velocity at t/2
The changes desired in the position and velocity at t/2 (i.e. -x'(t/2) and -z'(t/2)).
What do I need to do to find the changes in initial conditions. I've now spent 2 weeks on this trying every method I can find and so far nothing has worked.
If anyone needs any more info (numerical values of state trans matrix, initial conditions, etc) then just ask.
Gonna have to bump this.
2 weeks later, progress = 0.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
