Static equilibrium boy walking on beam
The discussion centers on a physics problem involving a uniform aluminum beam, 9.00 m long and weighing 300 N, supported symmetrically on two supports 5.00 m apart. A boy weighing 600 N walks from point A towards the right, with the critical question being how far beyond point B he can walk before the beam tips, which is determined to be 1.25 m. The second part of the problem requires calculating the optimal position for support B to prevent tipping when the boy reaches the end of the beam, which is solved by summing torques and results in support B being placed 1.5 m from the right end of the beam.
  • Understanding of static equilibrium principles
  • Knowledge of torque calculations in physics
  • Familiarity with forces acting on rigid bodies
  • Ability to analyze free-body diagrams
  • Study the concept of static equilibrium in physics
  • Learn how to calculate torques about different pivot points
  • Explore the principles of center of mass and its application in beam problems
  • Practice solving similar problems involving forces and moments
Students studying physics, particularly those focusing on mechanics, engineers involved in structural analysis, and educators teaching concepts of equilibrium and forces.
trajan22
quick question,
A uniform, aluminum beam 9.00 m long, weighting 300 N, rests symmetrically on two supports 5.00 m apart. A boy weighing 600 N starts at point A and walks toward the right.
How far beyond point B can the boy walk before the beam tips?
ans=1.25 m
How far from the right end of the beam should support B be placed so that the boy can walk just to the end of the beam without causing it to tip?
this second part is the part I am stuck on.
my equations are
all of these are the sum of the forces in that direction
Fx=0
no forces are acting in this direction
Fy=(F(support A)+F(support B))-(F(gravity on bar)+F(gravity on boy))
force of gravity of bar is at its center of mass between the two blocks
Tz=(F(gravity on bar)*(distance)-F(gravity on boy)*(distance))
rotation point is set around point b
i was able to solve for the first part of this problem however for the second part it appears that i have 2 unknowns with 1 effective equation so I am not really sure how to go.
i have included a figure but chances are it will take some time for it to come up.
trajan22 said:
quick question,
ans=1.25 m
my equations are
Fx=0
Your 2nd equation is a bit confusing. And I'm not sure how you solved the first part. In both cases, the beam is just about to tip when the reaction force at A is 0, because A can not support any upward force on it (assuming it isn't bolted or otherwise fastened to the beam).
Also in both cases, the sum of torques about any point must be zero, because the beam is in equilibrium as long as it is not tipping.
In part a, summing torques about B is easiest, because you know that the reaction at A is zero. Thus,
600x -300(2.5) = 0
x = 1.25 meters which agrees with your result.
In part b, you are trying to locate the position of support B such that no tipping occurs when the boy reaches the far end of the beam. Again summing torques about B,
600x - 300(4.5 -x) = 0
600x - 1350 + 300x = 0
x = 1.5 meters
Remember, the reaction at A is 0!
im confused about the last part of your explanation when you multiplied the 300 by (4.5-x) why by do you take half the length of the beam and subtract that from x...sorry i can't explain why i don't understand this in more detail.
The beam is 9m long; the cg of its weight, 300N, is located dead center at 4.5 m from the right end. The support B is located x meters from the right end. Draw a sketch showing the location of these 2 distances from the right end. It should then jump out at you that the 300N force is located (4.5-x) m from support B.
  • · Replies 18 ·
