Static Equilibrium Problem involving Moments
4 replies · 5K views · last reply
Anil Radhakrishnan
Free-body diagram of a flag pole hinged at point A on a wall, with a horizontal cable, a 10 kg point mass at the far end, an 80 kg rod at 30 degrees, and force Fx pointing right into the hinge; multiple-choice question 39 is shown.
Equations: Net torque=0=Net force
I believe this is a static equilibrium question but can't figure out how to do it
The net force on the x-axis must be zero. What equation can you make from this fact?
Also the net torque is zero. Take the torques around the A point. What equation can you make?
Solving these two equations with two unknowns (F_x and the force from cable ) will get you the result.
Handwritten physics working on lined paper: a rod on a 30 degree incline hinged at A, with tension T, weight Mg and (M+m)g labelled, and the equations for centre of mass and static equilibrium written below.
this is what i have split the forces as till now,
somehow i can't get them to cancel
You get involved with the forces along the line of the 80Kg rod, that's not what you should do, the x-axis is not the line of the 80Kg rod, the first picture at OP shows which are the x -axis and the y-axis.
In the y-axis you got the weights of the rod and the mass m, 80Kg and 10Kg respectively (and the F_y component of the force from wall at A).
In the x-axis you got F_x and the tension T from the cable.
ah got it thank you
