Static friction vs. Normal force on an incline
33 replies · 3K views
Alex75
I have two surfaces that have a coifficent of friction of .6. Disregarding mass (if possible) at what angle would the force of static friction and the normal force be equal
Not possible. The normal force depends on the mass. Since the frictional force is equal to the coefficient of friction times the normal force they can never be equal unless the coefficient of friction is one and that would be true of any angle.
This problem relates to woods chips sliding down a steel slide they range in mass from one gram to 500 grams what would the minimum angle be so that the normal force applied to every chip would overcome the force of static friction on each individual chip
I see the situation. The problem is asking at what angle will the chips begin to slide over one another. and that will occur when the force that is causing them to slide is equal to the frictional force that is preventing them from sliding. The normal force is not the force which will overcome the friction. The normal force is that which determines the frictional force. What force is acting such as to cause the chips down the slide?
The acceration of gravity acting soon an incline
Where m is mass
G is acceleration of gravity
° is the angle of the steel slide
N is normal force applied to object
No I am trying to determine the minimum angle the slide needs to be placed at so the chips accelerate down the slide. I.e. when the force from gravity is enough to overcome the static friction of the chips
That was the equation I found when reshuching frictional forces
Ff=un
Ff is frictional force
U is the coifficent of friction
N is normal force
None really outside college physics when I was a senior I have always had a love for science and physics though which is way I am attempting to educate myself on what I still need to learn and refresh what I already know
Do you remember the idea of the resolving (splitting) of a force ( i.e., a vector) into components? That is such that if you add the components you get the original force (vector) back>
I believe that was what we ended up doing in physics class to determine at what angle a car's tires would loose friction between the road surface
similarly here. The problem here is to find the angle of the slide and of the stack of chips such that the chips will just begin to slide over one another . The weight of the chips i.e. the force of gravity must be split into two components .1, one normal to the slide or chip surface pushing the chips together, and 2 one that is moving the chips down the slide. MgsinΘ is that component of the force of gravity that is acting to force the chips down the slide. Can you find or write down the normal force in terms of the mass and angle?
Wouldn't the normal force be N=mgcos°
So mgsin°=umgcos° would be the equation I would have to evaluate and isolate °?
OK I got that far on my own here's where the five years since when I last took physics becomes noticeable how do you isolate the angle from both triginomic functions
