Statics Question / Understanding Direction
  • Thread starter Thread starter Screen
    Direction Statics
1 reply · 2K views
Screen
I'm trying to understand how to determine the sign (+/-) of a given couple. In the sample problem below it shows the 30 lb couple (on the zy-plane) having a negative value for it's force. Is this found by using the RHR? And if so, in which direction do I orient my hand? In the positive direction of the axis it's parallel to?
[itex]M = Fd[/itex]
Right Hand Rule
I tried to depict the two orientations inside of the picture above.
Thank you for any help / feedback is appreciated.
I think you meant to say that it has a negative value for its moment? If you look at the couple you'll see that it causes a clockwise moment in the z-y plane which means it causes a negative moment in the z-y plane. This means that your thumb should be perpendicular to the z-y plane in order for the RHR to be obeyed and keep the same sign of the moment created.
