Steel tables for calculating axle diameter
In summary, the OP is trying to design an axle for a vehicle using the bending moments created with the applied force. He calculated the bending moment using the equation Sx = M/Fy. He is looking for a steel table to find the correct diameter for the axle, but he is struggling to find access to these tables. He has been taught a method for calculating the maximum stress in school, but it is useful for industry as well. He can find a steel table online if he needs it.
Wilson123
58
I'm in the process of calculating an axle diameter by using the bending moments which are created with the applied force on the end.
In order to design my axle to be efficient, I believe I need to use the following equation.
Sx = M/Fy
Sx being Plastic Modulus
Fy being Tensile strength of my chosen material
M being the worst case bending moment calculated
I have been told that once I've calculated my Sx, I need to look in the "steel tables" to find the correct diameter of steel tube to use for my axle, however I'm struggling to find access to these tables.
Can anyone point me in the right direction?
It has been many years since I did a shaft design, but I remember that the analysis method I learn during my University years included calculated maximum stress due to combined loads: bending, torsion, and tension if it applied. Stress concentration factors (keyways, machined shoulders, etc.) had to be included. Then it was necessary to find a steel type that had the necessary yield strength to meet the load that you calculated. Then finally it had to be analyzed for fatigue. Re-start, re-do, and iterate as required.
You can find lists of steels and their properties all over the internet if you search for steel properties. Then for very specific information about specific steel grades, you can always go to matweb.com .
Years later, I did a shaft design and discovered a brute-force, easy calculation method in Machinery's Handbook. It took simplistic formulas for gross loading and produced a minimum acceptable diameter for some sort of non-exotic and cheap steel round shaft stock like 1018 steel. The task was to simply upsize the shaft stock diameter to the next larger size off-the-shelf. I realized what was taught in the University was correct but never used in industry (except maybe aerospace or something). The Machinery Handbook's method was very much suited to industry needs: get the design done fast, use standard stock sizes of cheap steel, this enabled selection of standard bearing sizes and no heat treatments. Not elegant, but got the job done fast and effectively.
Likes Work Hard Play Hard
The info would be in a number of different engineering handbooks. Try getting a hold of a near by supplier and ask for their suppliers handbook\data sheets. They should just hand you what I think you are looking for, for free. The different suppliers generally offer the same or similar products. You might want to call beforehand and see if someone can give you a tour. You could learn a lot from it.
There's good reasons for process and showing your work in school that aren't always best on the job. Handbooks weren't developed to slow anyone down.
@Wilson123
First thing to do is define the problem .
Post a drawing showing the axle , related components , basic dimensions and the location and magnitude of the applied loads .
Nidum said:
@Wilson123
Hopefully the above diagram helps. I have calculated my reactions as 1.099kN on the left bearing and -0.0314kN on the right bearing. Giving me a bending moment of 0.063.
This over the tensile strength of steel (274 mPa) is 0.00023.
So I believe this to be my plastic modulas? (Sx) and I am looking for the right table to find a most suited axle diameter? I am aware this is a very low number I have come out with however I can justify an increase in this with a factor or safety being applied.
What are the distances from the load point to the centre bearing and from the centre bearing to the right hand bearing ?
0.08m to first bearing, 0.2m to second bearing from first bearing
The OP spoke of a "tube" for the axle. I would be leery of using tubular material for an axle because of the catastrophic failure associated with a wall collapse.
You could do the full bending moment calculation but if you are using a constant diameter axle then you only really need to find the maximum value .
Can you see where this will occur and what it's magnitude will be ?
Irrespective of whether the axle is constant diameter or not, what is usually significant is the maximum stress. This is often associated with the maximum bending moment, but not necessarily if the diameter is variable.
Now that I have my bending moment, what is the next step towards calculating my shaft diameter?
Will this axle be carrying torque, or not? If there is a torque involved, that must also be determined before the stress analysis can proceed.
By 'carrying torque' to mean will it be being driven by something? If so, then yes
If the shaft supports both bending and torsion, the result is a combined state of stress. Both must be considered together (not separately) in order to make the necessary stress analysis.
Are the equations shown here https://theconstructor.org/structur...d-bending-direct-and-torsional-stresses/3704/ what I need to use to do this?
I've calculated my bending stress as 50.4 and my torsional stress as 10.2 using the method shown in that linked page. I'm unsure how I know what my axial thrust is for calculating direct stress?
No, those are not quite right for your case. Those apply to the situation where the shaft is non-rotating, but for a rotating shaft, the bending stresses are reversed with every shaft rotation. You are looking at a fatigue problem here, and fatigue can let you down, big time!
I suggest that you look at a machine design textbook, such as Shigley or Spotts and study carefully what they have to say about shaft design. It is not a trivial problem
Thanks for your help, I'll look into this ASAP.
Regarding axial thrust, is there a way to determine what this load is for my circumstance? I understand it may not be a formula, just what factors I need to consider.
@ Wilson : Perhaps if we apply some rudimentary engineering knowledge to this problem we might get somewhere .
Is it correct that there is no significant end load on the axle and that rotational speeds are low ?
What are the practical limits of diameter for the axle ?
Are there any stock bar sizes that would be convenient to use if they could be shown to be adequately strong ?
Does the axle have to fit bore of any particular bearings ?
1. Only the load shown in the previous diagram and this axle will be manually driven at low speeds.
2. Between 10mm and 23mm.
3. Preferably a stock bar sized would be used for the axle to keep costs down, so the closest one to the needed axle.
4. I am yet to select my bearings but only plan on using standard ball bearings so bore diameter should be able to vary as needed.
Hope this helps.
Lets see where we go with 20 mm .
With your calculated value of bending moment what would be the maximum stress level in an axle made from this diameter bar ?
Please let us know if you are not sure how to do the calculation .
By maximum stress level is that the bending stress? which is My/I
m= moment
y= radius
I = moment of intertia
That's it .
nb: The ' I ' should properly be called the Second Moment of Area rather than the Moment of Inertia .
Nidum said:
That's it .
Thank you.
Second moment of area being calculated by pi/4 * r^4 ?
By doing this I get 0.063 * 0.01 / 7.85398 x10-9 = 80214 as the bending stress?
Yes .
nb: Try using the x2 function in the tool bar for writing things like r4 . Would be worth learning the basics of LaTex as well
Thanks, I will do. Now that I have this bending stress for a 20mm diameter shaft, how do I decide if this is suitable for my application?
Or do we now look at torsional stress?
What units ?
0.063kNm * 0.01m / 7.85398 x10-9m4
0.00063kNm2 / 7.85398 x10-9m4
80214kNm-2 (Not too sure on these units, what should they be?)
Well I think that is 80 MPa which is correct .
Now we need to workout the deflection at the free end of the axle where the 785 N load is applied .
Can you do that ?
  • #31
Ah yes, I forgot to convert to MPa.
I am familiar with deflection however not sure how to calculate it under these parameters, could you give me some pointers?
  • #32
Just to be clear on one point - Is there another extension and load at the other end of the axle ?
Likes Wilson123
  • #33
No there isn't, my design has one axle per wheel, so the other wheel is supported by a mirror image of this axle.
  • #34
After looking over my calculations, I've realized I had my bending moment slightly too high, therefore my bending stress is wrong. My bending stress is actually 63MPa.
  • #35
Do you still want any help with this problem ?
<h2>1. What is the purpose of steel tables for calculating axle diameter?</h2><p>The purpose of steel tables for calculating axle diameter is to provide a quick and accurate way to determine the appropriate diameter for an axle based on the load it will be carrying. This is crucial for ensuring the safety and efficiency of various machines and structures that rely on axles.</p><h2>2. How are steel tables for calculating axle diameter created?</h2><p>Steel tables for calculating axle diameter are created through extensive testing and analysis of various factors such as load, material properties, and axle design. This data is then compiled and organized into a table format for easy reference.</p><h2>3. Are steel tables for calculating axle diameter accurate for all types of axles?</h2><p>Steel tables for calculating axle diameter are typically accurate for standard axles made of steel or other common materials. However, they may not be suitable for specialized or custom axles made of different materials or with unique designs.</p><h2>4. Can steel tables for calculating axle diameter be used for both static and dynamic loads?</h2><p>Yes, steel tables for calculating axle diameter can be used for both static and dynamic loads. However, it is important to note that dynamic loads may require additional factors to be considered, such as impact and fatigue, which may not be accounted for in the tables.</p><h2>5. Are there any limitations to using steel tables for calculating axle diameter?</h2><p>While steel tables for calculating axle diameter are a useful tool, they should not be relied upon as the sole method for determining axle diameter. Other factors such as environmental conditions, manufacturing tolerances, and safety margins should also be taken into account.</p>
  • Mechanical Engineering
