ga5aq
- 3
My name is Gai Abraham, an automotive engineer trying to build a little LEV (low emission vehicle)
I have contacted you previously and I wish to ask further help on the bending of steel tubes.
Namely I have designed a chassis from bent steel tube, the technical sheet on S.S. astm 301 allows, depending on the hardness of the tube, to have elongations ranging from 40% (for annealed) up to 9% (for full hard) from original length.
The issue I am trying to solve is whether the original length is the midline of the tube, giving during bending, compression on the inlay and tension on the outlay for final plastic bending
or the original length is the inside radius of the curved tube and gradually all the tube stands deformation up to a maximum value on the outer side?
I think that if the tube is held in position and supported on the inside while curving it, the original length is the inside radius since it was not able to compress.
thank you
Gai
ga5aq@yahoo.com
thank you
Gai
ga5aq@yahoo.com
