Stokes's theorem in spherical coordinates
17 replies · 11K views
wifi
Problem:
Say we have a vector function ##\vec{F} (\vec{r})=\hat{\phi}##.
a. Calculate ##\oint_C \vec{F} \cdot d\vec{\ell}##, where C is the circle of radius R in the xy plane centered at the origin
b. Calculate ##\int_H \nabla \times \vec{F} \cdot d\vec{a}##, where H is the hemisphere above the xy plane with boundary curve C.
c. Calculate ##\int_D \nabla \times \vec{F} \cdot d\vec{a}##, where D is the disk in the xy plane bounded by C.
(Verify Stokes's theorem in both cases.)
Solution:
First off, isn't it unnecessary to say verify Stokes's theorem in both cases? If we calculate a line integral, and then a surface integral bounded by the same curve, Stokes's theorem states that they're the same, yes?
Moving on...
a. We have [tex]\vec{F} \cdot d\vec{\ell}=(0,0,1)(dr, d\theta, rsin\theta \ d\phi)=rsin\theta \ d\phi[/tex]
So [tex]\oint_C \vec{F} \cdot d\vec{\ell} = Rsin\theta \int_0^{2 \pi} d\phi= 2 \pi R sin \theta[/tex]
Is this correct?
b. We have ##F_r=F_{\theta}=0## and ##F_{\phi}=1##, so for the curl I find [tex]\nabla \times \vec{F}=(\frac{1}{r}tan\theta, 0, -\frac{1}{r})[/tex]
I think this is right so far. But in calculating ##\int_H \nabla \times \vec{F} \cdot d\vec{a}##, I'm not sure what to use as ##d\vec{a}##. Any help? Thanks in advance.
wifi said:
Problem:
"Verify Stoke's theorem" means "observe that the line integral is indeed equal to the surface integrals"
Moving on...
Is this correct?
No. The circle in question is [itex]r = R[/itex], [itex]\theta = \pi/2[/itex] and [itex]\phi \in [0, 2\pi)[/itex]. Thus the element of line length is [itex]\mathrm{d}\vec{l} = R\hat\phi \mathrm{d}\phi[/itex], and the integral is
[tex] \oint_C \vec F \cdot \mathrm{d}\vec{l} = \int_0^{2\pi} R\mathrm{d}\phi[/tex]
I get [itex]\nabla \times \vec F = r^{-1}\tan\theta \hat r - r^{-1}\hat\theta[/itex].
[itex]d\vec a[/itex] is the normal to the surface in question times the element of area. Given the choice of parametrization of the line integral, it's the normal with the non-negative [itex]\hat z[/itex] component.
Ah, I see. So it's simply the perimeter of a circle. Makes sense. [tex]\int_0^{2\pi} R\mathrm{d}\phi = 2\pi R[/tex]
Whoops, yeah that's what I meant.
Well in class my prof used ##r^2sin \theta d\theta d \hat{\phi}##. Is that correct? If so, I would like to understand why that's the case.
Thanks, pasmith.
No, that's not correct. ##d\vec{a}## points in the direction normal to the surface. For the hemisphere, this would be radially outward, so ##d\vec{a}## points in the ##\hat{r}## direction. The magnitude of the area element is ##R^2\sin\theta\,d\theta\,d\phi##.
That makes perfect sense. So it's ##d\vec{a}=R^2sin \ \theta \ d\theta \ d\phi \ \hat{r}##, right?
So when I calculate ## \int_H \nabla \times \vec{F} \cdot d\vec{a} ## does ##r \rightarrow R## in ##\nabla \times \vec{F}=(\frac{1}{r}tan \ \theta, -\frac{1}{r}, 0)##? (ie. is it ##\nabla \times \vec{F}=(\frac{1}{R}tan \ \theta, -\frac{1}{R}, 0)##?)
Okay. I have to integrate ##sin \ \theta \ tan \ \theta##. This is going to be a mess...
Uh oh, on wolfram alpha it's saying this integral does not converge. Something has to be wrong.
## \int_H \nabla \times \vec{F} \cdot d\vec{a} = \int (\frac{1}{R}tan \ \theta, -\frac{1}{R},0) \cdot (R^2 sin \ \theta \ d\theta \ d\phi, 0, 0) = \int_0^{2 \pi} \int_0^{\pi} R sin \ \theta \ tan \theta \ d\theta \ d\phi ##. Yes?
Yeah I get ##\int_0^{2 \pi} \int_0^{\pi} R cos \ \theta \ d\theta \ d\phi = 2 \pi R##.
Hopefully I can get part c. with no difficulty. I'll keep you posted.
So, for the disk we have ## d\vec{A}= - R^2 sin \ \theta \ d\theta \ d \phi \ \hat{\theta}##?
That integral as written should evaluate to ##4\pi R.##
Nope. For one thing, r isn't constant over the disk. What should the magnitude of the area element be? Which way should it point?
Ah, ##\theta## should range from 0 to pi/2. Then the integral is correct.
I'm not sure about the magnitude, but it should point in the +z direction.
##d\vec{A}=-rdrd\phi \hat{\theta}##. Using this in the integral (with r:0 to R and Φ:0 to 2π), I get ##2 \pi R##, as expected. Is this correct?
