hatchelhoff
- 64
- 0
A Steel bolt having nominal Diameter of 20 mm and a pitch of 2.5 mm
(Pitch is the distance from thread to thread in the axial direction), and an aliminium tube,
40 mm OD by 22 mm ID, act as a spacer for two plates. The distance between the two plates is 0.35 m. The nut is pulled snug and then given a one-third additional turn. Find the resulting stress in the bolt and in the tube, neglecting the deformation of the plates
(The correct answers are 241 MPa and -86.3 MPa
\tau = Shear Stress, \lambda = Shear Strain
σ = F/A, ε = Elongation/Origional Length, σ = Modulus of Elasticity x ε
Elongation = (Force x Length) / (AE), v = -Lateral Strain/axial Strain
E = 2G(1 + v), ε1 = σ1/E - vσ2/E, σ1 = (E(ε1 + vε2))/(1-vxv)
\tau = G\lambda
For Uniaxial Stress
ϵ1 = (σ1/E), ε2 = -v*ε1, ε2 = -v*ε1,
For Biaxial stress
ϵ1 = (σ1/E) -(v.σ2/E)
ϵ2 = (σ2/E) -(v.σ1/E)
ϵ3 = v.(σ1/E) - v.(σ2/E)
For Triaxial Stress
ϵ1 = (σ1/E) -(v.σ2/E) -(v.σ3/E)
ϵ2 = (σ2/E) -(v.σ1/E) -(v.σ3/E)
ϵ3 = (σ3/E) -(v.σ1/E) -(v.σ2/E)
Part A
The steel bolt is in a state of uniaxial stress
ϵ1 = (σ1/E)
ϵ1 = Elongation/ Origional Length
Elongation = 2.5 mm / 3 = 0.83333 mm
ε1 = 0.83333/ 350 mm = 0.002381
I am saying that since the bolt is steel, E = 200 GPa
Therefore
σ1 = ε1 * E = 0.002381 * 200 GPA = 476 MPa
