Strange simultaneous eqution problem?
  • Thread starter Thread starter smileandbehappy
    Strange
The discussion revolves around solving a system of simultaneous equations involving a variable k. Participants suggest various methods for finding solutions, including elimination, matrix equations, and Cayley's method, emphasizing the importance of identifying when k causes division by zero or results in a non-invertible matrix. It is noted that the problem is typical and straightforward, with two specific values of z leading to no solution. The conversation highlights the interconnectedness of different solving techniques. Ultimately, understanding the implications of k is crucial for determining valid solutions.
smileandbehappy
I have a few of these to do so would appretiate if someone could explain this to me as i am stumped.
Find in terms of k a solution to the equations,
x+y+kz=4
x-2y-z=1
kx+7y+5z=10
For what values of k is this solution not valid?
Man thanks in advance for any help given.
Mathematics news on Phys.org
x+y+kz=4
x-2y-z=1
kx+7y+5z=10
Doesn't look strange to me, looks like a fairly typical problem.
How you would do it depends upon how you want to solve simultaneous linear equations! Some people might eliminate one variable at a time. If you do it that way, you will want to keep track divisions by a quantity involving k. For what values of k would you be dividing by 0? Others might set it up as a matrix equation and find the inverse of the coefficient matrix. For what values of k does that matrix not have an inverse? Still others might use Cayley's method: each solution is a fraction in which the denominator is the determinant formed by the coefficients. For what values of k is that determinant equal to 0? Of course, a little reflection will show you that all of those methods are really the same thing!
OK then. Will you show me how to do the elimination method?
Use elementary row operations, at least to put into, ?triangular form? What course are you studying? If linear algebra, then the system should be easy to solve. You could read about one or two methods from an intermediate algebra book just as well.
This link takes you through a 3 x 3 example of elimination:
http://en.wikipedia.org/wiki/Gaussian_elimination
This problem is quite straightforward. There are two values of z (both whole numbers) that result in no solution. The solution to a quadratic equation is involved.
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
