Sahar ali
- 10
- 1
As Hs (stray field)= -Hd (demagnetizing field), What will happen if we minimize the stray field? Does minimize stray field will also reduce the strength of demagnetizing field? If yes then how will we minimize stray field so that it does not affect the demagnetizing field?
here few lines about the stray field and demagnetizing field is taken from
J. St¨ohr H.C. Siegmann
Magnetism From Fundamentals to Nanoscale Dynamics
To understand the nature of the three magnetic vectors B, H, and M.
We use the example of a flat ferromagnetic disk that has been perpendicularly
magnetized, by an external magnetic field. After this
process, the external magnetic field has been turned off, so that we consider
only the field generated by the ferromagnetic disk itself
In the absence of an external magnetic field, a flat disk magnetized perpendicular
to the surface is characterized by the three magnetic vectors B, H, and
M, The magnetic field inside the magnetic material is called the demagnetizing
field Hd because it is oriented opposite to the magnetization M, thus
tending to destroy it. The field outside the material is called the stray field Hs and
it loops around in space.
