Stress compound cylinder problem
  • Thread starter Thread starter jakeward46
    Cylinder Stress
The discussion centers on the stress analysis of a compound cylinder subjected to an internal pressure of 50MPa. The inner tube has an inside diameter of 40mm and an outside diameter of 60mm, while the outer tube has an outside diameter of 80mm. Using Lame's equations, the calculated hoop stress for the inner tube is 83.3MPa and for the outer tube is 33.3MPa, indicating that the maximum stress occurs in the inner cylinder. The analysis confirms that both tubes are made of the same material, as evidenced by the single Young's modulus value of 207000 N/mm².
  • Understanding of Lame's equations for cylindrical stress analysis
  • Knowledge of material properties, specifically Young's modulus
  • Familiarity with concepts of internal pressure and interference fit
  • Basic skills in stress calculation and mechanics of materials
  • Study advanced applications of Lame's equations in compound cylinder analysis
  • Learn about the effects of interference fit on stress distribution in cylindrical structures
  • Explore the implications of material selection on stress analysis in engineering
  • Investigate methods for calculating stress in composite materials under pressure
Mechanical engineers, students studying solid mechanics, and professionals involved in the design and analysis of pressure vessels and cylindrical structures will benefit from this discussion.
jakeward46
A tube 40mm inside and 60mm outside dia is to be reinforced by shrinking on a tube of 80mm outside diameter. The compound tube is subjected to an internal pressure of 50MPa and the shrinkage allowance is such that the final maximum stress in each tube is the same. Determine the maximum stress and the difference in tube diameter before shrinkage. E=207000 N/mm^2
Lames equations:
Radial stress σr=A-B/r^2
Hoop stress σθ=A+B/r^2
Ive attempted the first part of the question however i have ended up with a negative maximum stress which cannot be. If someone could point out my mistake or give advice that would be great :)
Usually, a negative stress indicates the member is in compression.
Ok thanks, so my answer is an acceptable one? I didn't think that would apply to cylinders.
I have just worked the calculation again and got A=16666687.5 and B=26666.7 and subbing into lames eqautuon for hoop stress in and out
σθin= 83.3MPa
σθout= 33.3MPa
this seems a more realistic answer, showing max stress is in the inside of the cylinder. ?
just looked at your working how did you now that the compound cylinder was made up of the same material, is that from the one value of young's modulus? also did you work out the stress produced from the shrink fit not just the internal pressure?
Yes as there is only one youngs mod given i would of thought it is the same material?
Ive been working on it and i have worked out the stress due to interference fit first and then calulated with internal pressure. not realising i had to to this at first.
11K
