How Do You Simplify Complex Fractions with Different Denominators?
  • Thread starter Thread starter AznBoi
    Fraction
To simplify the complex fractions \(\frac{5}{a} + \frac{4}{2a-6} + \frac{-4a}{a^{2}-9}\), the common denominator identified is \(a(a+3)(a-3)\). The user initially struggled with combining the fractions and correctly identifying the common denominator. After some discussion, they clarified that \(2a-6\) can be factored to \(2(a-3)\), and \(a^2-9\) factors to \((a+3)(a-3)\). The conversation highlights the importance of recognizing common factors in the denominators to simplify the expression effectively. Overall, understanding the common denominator is key to combining and simplifying complex fractions.
AznBoi
Here is the fraction that I don't know how to combine and simplify, please help me out! Thanks! =]
\frac{5}{a} + \frac{4}{2a-6} + \frac {-4a}{a^{2}-9}
I found the common denominator I think: (x+3)(x-3) .. but how do you make {a} in that form?
Mathematics news on Phys.org
If I write it as \frac{5}{a}+\frac{2}{(a-3)}-\frac{4a}{(a+3)(a-3)} does it help?
Ok, I didn't see the bit you'd edited. The common denominator will be a(a+3)(a-3).
oh ok, I knew there wasn't a way to make {a} into {(a+3)(a-3)}. Thanks for your help! =]
You're very welcome!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
