How Do You Solve the Hamiltonian for a Two-Electron Ferromagnet?
  • Thread starter Thread starter vputz
    Spin Stupid
vputz
Okay, this would be easy if it hadn't been 15 years since undergrad quantum. Here goes.
I'm finding the energy spectrum of a Heisenberg "two-electron ferromagnet", if you will, with a Hamiltonian described by
H=-J\hat{S_1}\cdot\hat{S_2}-h(\hat{S_{z1}}+\hat{S_{z2}})
Well, after a while of dusting off my brain and groveling to fellow students, I figured out that
(\hat{S_1}+\hat{S_2})^2 = \hat{S_1}^2 + \hat{S_2}^2 + 2\hat{S_1}\cdot\hat{S_2} \rightarrow \hat{S_1}\cdot\hat{S_2} = \frac{1}{2}( (\hat{S_1}+\hat{S_2})^2 -\hat{S_1}^2 -\hat{S_2}^2 )
So my Hamiltonian is now
H = -\frac{1}{2}J((\hat{S_1}+\hat{S_2})^2 - \hat{S_1}^2 -\hat{S_2}^2 ) - h(\hat{S_{z1}}+\hat{S_{z2}})
Okay. Now, the eigenvalues of \hat{S}^2 are s(s+1) (we're doing the usual \hbar=1 trick). And the eigenvalues of \hat{S_z} are m. And I know that electrons have s=\frac{1}{2} and m=-s...s in integer steps.
So... it should just be a matter of plugging in possible values for, er, s&m, so to speak. But the (\hat{S_1}+\hat{S_2})^2 term confuses me. My gut feeling is to treat that as an \hat{S}^2 term but use values -1,0,1 as possible values of \hat{S_1}+\hat{S_2}. Is that the right way to handle it?
yes, that's roughly right.
Your H may be written as -J/2 ( S_{tot}^2 - S_1^2 - S_2^2 -h S_{tot,z})
This is diagonal if you use for basis the three spin 1 states. Applying S_{tot}^2will give 1 \times (1+1) \hbar^2 = 2 \hbar^2 for any of the spin 1 states. Applying S_1^2 or S_2^2 will give 1/2(1/2+1) hbar^2 = 3/4 \hbar^2. The only term that will distinguish between the three S=1 states is the S_{tot,z} operator that gives m_{tot} \hbar.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
