Sudden polarity reversal in opposing permanent magnets?
In summary, when two magnets are pressed together in opposition, they lose some of their magnetization.
sw20
Hi all,
I'm working with a pair of multi-pole neodymium ring magnets (rated ~119lbF) and finding that if the opposing poles are forced together, with the magnets in alignment, that at very close range (may be a millimeter or two apart?) the two magnets will suddenly snap together as if one has reversed polarity. There is NO electric current involved, but the only resources I am finding about this phenomenom are related to electromagnets and induced magnetism.
Can anyone point me to a source explaining what's happening?
Thank you!
sw20 said:
Summary:: Opposing permanent ring magnets, when forced close together in alignment, suddenly attract. Need help finding resources explaining why.
Hi all,
I'm working with a pair of multi-pole neodymium ring magnets (~55lbF) and finding that if the opposing poles are forced together, with the magnets in alignment, that at very close range (may be a millimeter or two apart?) the two magnets will suddenly snap together as if one has reversed polarity. There is NO electric current involved, but the only resources I am finding about this phenomenom are related to electromagnets and induced magnetism.
Thank you!
Welcome to the PF. :smile:
What's a "ring" magnet?
Can you post a link to the datasheet or more information about these magnets? Thanks.
sw20 said:
https://www.mcmaster.com/2494N17
Ring magnet is a magnet with a hole in the middle, like a donut.
Hmm, that is confusing to me. They show discrete poles on the top (and also "N" on the bottom?), which implies that there are S pole areas between them on the top surface. It looks like they are designed for high attachment force in contact with a ferrous metal, not for interaction with other magnets. Do the two magnets feel like they twist at all when you say the force turns attractive between them?
A multipole cylindrical magnet would seem to have this kind of magnetic field distribution...
https://www.hsmagnets.com/wp-content/uploads/2015/11/D_plot_of_multipole_ring_magnets.jpg
Yeah, McMaster detail drawings aren't always quite right, though, so I don't know how trustworthy that is. They do have clearly marked sides, with matching-marks being VERY attracted to each other and non-marked sides repelling. No, they don't twist, which I also initially thought might be happening, but it's not.
I'm going to try to repeat this with "standard" magnets after I get off a work call.
Keep in mind that when you are pressing magnets together in opposition, you probably are causing a partial loss of magnetization. So the magnets will not be as strong after you do this a few times. How much is lost depends on the kind of the magnet.
http://www.mceproducts.com/Knowledge_Base/Articles/Demagnetization_of_Permanent_Magnets.htm
https://www.duramag.com/techtalk/te...ure-and-demagnetization-from-external-fields/
Demagnetizing from External Fields
Magnet alloy is magnetized with a sufficiently intense magnetic field that is established in the same direction as the magnet’s orientation. When a magnetized magnet is exposed to a strong magnetic field that is established in opposition to the magnet’s magnetization, part of the magnet may be demagnetized. This demagnetization essentially reduces the effective field of the magnet and the magnet’s performance will therefore degrade.External demagnetizing fields can originate from fields created by electromagnets/coils or other neighboring permanent magnets. An example of a coil would be a motor application where the dynamic fields created by a coil set interact with fields from permanent magnets to create motion. An example of a static case of demagnetizing fields from neighboring permanent magnets could be a Halbach Array where some internal magnets have a poor L/D and low Hci and are demagnetized from other array magnets. A dynamic case could be a permanent magnetic toque coupler which “slips” and like magnet poles rotate over one another.
I noticed a similar phenomenon in a magnetic drive I made for a magnetic Tesla Turbine. With a certain spacing, there seems to be a sweet zone where the fields interlock and provide attraction, from a normally repelling mode.
Here is my demo of the "Magic Magnetic Coupler" where the effect is shown:
Related to Sudden polarity reversal in opposing permanent magnets?
1. What is a sudden polarity reversal in opposing permanent magnets?
A sudden polarity reversal in opposing permanent magnets refers to a phenomenon where the north and south poles of two magnets suddenly switch places, resulting in an attraction between the previously repelling magnets.
2. What causes a sudden polarity reversal in opposing permanent magnets?
The exact cause of a sudden polarity reversal in opposing permanent magnets is not fully understood, but it is believed to be due to external factors such as temperature changes, magnetic fields, or physical shocks to the magnets.
3. Can a sudden polarity reversal in opposing permanent magnets be predicted?
No, a sudden polarity reversal in opposing permanent magnets cannot be predicted as it is a random and unpredictable event. However, certain conditions may increase the likelihood of a reversal occurring.
4. Is a sudden polarity reversal in opposing permanent magnets harmful?
No, a sudden polarity reversal in opposing permanent magnets is not harmful. It is a natural occurrence in magnets and does not affect their overall functionality or strength.
5. How can a sudden polarity reversal in opposing permanent magnets be reversed?
A sudden polarity reversal in opposing permanent magnets cannot be reversed. However, the magnets can be physically realigned to restore their original polarity if desired.
  • Electromagnetism
  • Electrical Engineering
